Question about AT&T 210 Trimline Memory Telephone (att-93040)
How do I take an at&t model 210 apart?
I need to take it apart so I can paint the handset red to ID it as an emergency phone.
Deregister AT&T SL82118 handset
The following is for the model ATT 5830.
Enter the following sequence on the base station including the * symbols.
**335782
This will deregister all handsets associated with that base station. Handsets can then be added back into the system by entering the base station ID into the handsets one by one. The base station ID is on the bottom of the base station itself.
Feb 06, 2014 | AT&T 5830 Cordless Phone
I am trying to set up my know phone model kxtg6545 and want to eliminate the caller announcement feature I do have voicemail and do not use the answering system please help
Talking Caller ID is enabled/disabled separately for the the base unit & handsets:
Handset - Menu # 1 6 2 0 - Save - then 'Off''
Base Unit - (From any handset keypad) Menu # * 1 6 2 0 - Save - then 'Off'
Feb 15, 2011 | Panasonic Cell Phones
Can't listen to my voicmail
Click on a left side link of download manuels. ------------ 40000 series DS4122-4 ------------ 50000 series cs5121-4 ------------ i6785 English Not sure what series you have, but take a look at these manuels. found here :http://www.vtechphones.com/vtechui/support/manual_list.cfm#214 if not anyof these listed- there are many others to view and I know you'll find right instructions here!! Let me know if this helped.--Stevie ----------------------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID ------------------------------- 5.8 GHz digital Four Handset Cordless Phone System with Digital Answering System and Caller ID --------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID i6785 - Spanish 5.8 GHz Digital four handset telephone system with digital answering system english i6786 5.8 GHz digital four handset cordless phone system with caller ID and digital answering device i6786 - Spanish 5.8 GHz digital four handset cordless phone system with caller ID & digital answering system
Feb 14, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
I need the base id for a vtech house phone model number 6772
It sounds like you are trying to register the handset(s) to the base. Once the handset is charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit press MENU, scroll down to Display Base ID, press OK, and the Base ID code will display. If NEW appears in your handset display, press the soft key under it and enter the base ID code you found in the base display. If 'New' does not appear on your handset, press MENU and then scroll down to REGISTER. Press OK and then enter the base ID code. If the handset is already registered, please deregister all then register again. To deregister a handset which is registered to the base model 20-2431, Using the soft keys on the base, press the 'MENU', then press the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted. Press 'SET' . If your handset is registered to the base model 20-2481, Using the soft keys on the base, press the 'MENU', then press the down arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
Jul 11, 2009 | Lands Phones
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
My DCT646-2 no one can hear me.
take it apart and clean the mic with alcohol. (I took out a black round cover it had on top to reduce eco)
Worked for me.
cheers,
Oct 04, 2007 | Uniden DCT646-3 Cordless Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
AT&T 210 Trimline Memory Telephone (att-93040) Logo
21 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
