Question about Avaya Definity 6424D+M Corded Phone
HOW DO i PROGRAM SIDE BUTTONS
Does the Administrator have to do this
Crime stories will not start in win 7
uninstall then before installing again if u have it on external drive or zip file drag to desktop which is the homescreen with the icons right click the setup go down to properties a window should come up go to the compatibility tab at the top it should be the second one check the box "run this program in campatability for" if it is an older program it will most likely perform better in "windows xp (service pack 2)" then at the bottom check the box "run this program as an administrator" at the lower right side of the window click apply then "ok" to exit go back to the setup right click again and click run as administrator this should install and run correctly
Mar 14, 2012 | Video Game Consoles & Games
Please i need help on how to program extension on each phone
The FixYa GuessYa is that you want to program the extensions on the spare buttons on each phone. The 12 left side buttons will let you do that, the 12 buttons on the right are pretty much worthless, but this is a 77xx series phone, right?
To program extensions on the left side, label the strip, then press PROGRAM the button and dial 1 + extension and STORE. Keep doing that until you run out of buttons. If you slip and accidently reassign a line button, those are programmed with 0 + line number (1-8 in a TA series) STORE.
Pick up the handset and drop it back down when you're finished to exit programming. In a TA-824, there's a programming tool that let's you do this from a computer and copy buttons, but most of the time it's a lot easier to just do it by hand.
Carl
Apr 20, 2011 | Panasonic KX-T7730 Corded Phone
IS NOT CAMPATIBLE WITH WIN 7
Run the Program Compatibility Wizard
  1. Open the Program Compatibility Wizard by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
  2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Setting
Description
Compatibility mode
Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.
Run in 256 colors
Uses a limited set of colors in the program. Some older programs are designed to use fewer colors.
Run in 640 × 480 screen resolution
Runs the program in a smaller-sized window. Try this setting if the graphical user interface appears jagged or is rendered improperly.
Disable visual themes
Disables themes on the program. Try this setting if you notice problems with the menus or buttons on the title bar of the program.
Disable desktop composition
Turns off transparency and other advanced display features. Choose this setting if window movement appears erratic or you notice other display problems.
Disable display scaling on high DPI settings
Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program. For more information, see Make the text on your screen larger or smaller and Ways to improve display quality.
Privilege level
Runs the program as an administrator. Some programs require administrator privileges to run properly. If you are not currently logged on as an administrator, this option is not available.
Show settings for all users
Lets you choose settings that will apply to all users on this computer.
Dec 27, 2010 | Computers & Internet
How to program store number in the KXT7730
Under any system, you can always press PROGRAM + a button, dial a sequence and press STORE. What number are you dialing?
If it's an outside number, then the sequence is generally 29 on the left side or 9 on the right side buttons. If inside, then 1+ext on left and ext on right. The left side buttons have lights and will monitor extensions.
Carl
Nov 29, 2010 | Panasonic KX-T7730 Corded Phone
I am getting a pref.Out :NO .. after I press the program> auto Dial> then I press 10 ( which is the line I want to store a number on ) and the I get pref.Out :NO
HUH? You program autodial for the SYSTEM from a SYSTEM phone in SYSTEM programming. You program the "auto dial" buttons, the ones on the right side of your phone from the phone by pressing PROGRAM one of the 12 buttons and dialing "9" plus the number SAVE.
If you are trying to program one of the left side buttons for autodial (bad move) then you dial "29" first.
Carl
Oct 19, 2010 | Panasonic KX-T7731 Corded Phone
How can I set speed dial if my phone is not the main telephone
If you have a USB port on the side of the cabinet, you can program it from the maintenance console. You can also program "personal" speed dial number in the 12 feature buttons on the right side of the phone, and/or under the dial pad on certain systems. To program the buttons, press PROGRAM the button and dial the number with an access code in front (usually 9) then STORE. So, to call 555-1212 you'd dial 9555-1212 STORE. and pick up the handset and drop it back down to end programming.
If you figure out how to program numbers under the dial pad buttons 1-0 keep in mind that it overwrites the F1-F10 keys.
Carl
Sep 15, 2010 | Panasonic KX-T7730 Corded Phone
How do you program your wireless mouse so the side buttons work correctly
In order for you to program the Logitech wireless mouse, you need to install the software (CD) that came with it.
You need to launch the software after installing it, and there will be an option for you to program the side buttons as how you would like it to work. Example, you selected the upper side button to launch your Internet Explorer. All the instructions will be available in the software itself.
You may also refer to the user manual of the mouse.
Thank you and good luck!
Jun 16, 2010 | Logitech Cordless Mouse
How do I program the speed dial buttons? thanks
A 7730 phone has 24 buttons. The left side buttons are CO buttons with lights, the right side are Personal Feature buttons. To program the buttons on the right side, you press PROGRAM, the button, and dial 9-and the number then STORE. The left side buttons require a "2" first.
Carl
Oct 22, 2009 | Panasonic KX-T7730 Corded Phone
Acer aspire 5630. The volume, play, stop won't work
re-install the original drivers and program for control buttons.
Jun 04, 2009 | Acer Aspire 5500 5570-2609 Laptop
I am trying to install a photosmart all in one C5180 on my pc running Vista. It keeps saying that the program cannot be installed as use by and asking me to log on as the Administrator. I AM the...
This is normal with Vista, Vista log in users as standard (not Administrator privileges) , then ask if to run programs as administrator for security reasons. Once you tell the system to run program as administrator it should install with no problems.
If you really cannot install the program, you can restart computer and login as administrator:
At the "pick a user to login" screen, hit CTRL-ALT-DEL to get the classic login screen. Then you can type in Administrator for the user name, default password is blank.
Read here for more.
Jun 08, 2008 | HP Office Equipment & Supplies
Avaya Definity 6424D+M Corded Phone Logo
27 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
