Question about Wasp WPL205 Thermal Label Printer
Wasp printer offline - Wasp WPL205 Thermal Label Printer
Wasp wpl 305e
The WPL 305 E is Ink side IN or OUT? And the core is?
Dec 05, 2013 | Wasp WPL305 Printer
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
Hp deskje d2360 printer showing offline error
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
How to replace printhead wasp 305
Remove the ribbon. On each side of the head is a small yellow tab. Push one side in then drop that side of the head and pull the other side out. Disconnect the connector on the back.
Aug 30, 2010 | Wasp WPL305 Thermal Label Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Label gap
probably your label not ok,or you have some label stick on the sensor in the printer.open the printer and check
Feb 07, 2008 | Wasp WPL606 Thermal Label Printer
Wasp WPL205 Thermal Label Printer Logo
29 people viewed this question
Top Wasp Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Wasp Office Equipment and Supply Expert? Answer questions, earn points and help others
