Question about LG 52LD550 52Inch 1080p 120Hz LCD HDTV Black 52 in TV
Hdmi ports stopped working - LG 52LD550 52Inch 1080p 120Hz LCD HDTV Black 52 in TV
2 Suggested Answers
vinceisaac
  • 2432 Answers
SOURCE: HDMI PORTS NOT WORKING
how about other component input also not working .
Posted on Sep 23, 2012
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
Phillips hdmi ports not working
Yes,
When 1 HDMI port is broken most of the time all the ports are defect. This is because all the 3 HDMI ports are connected to 1 multiplexer IC. Only when the connector or the copper connection on the board is damaged the other two ports still be functional.
You still can use the other connections ( not HDMI) the should be working.
Regards GJ
Jun 14, 2014 | Philips 42PFL5332D 42 in. LCD Television
HDMI Ports on Toshiba Flat Screen TV stopped working
That's highly unlikely!!! More likely is that the cable is having problems or that someone mistakenly changed the picture i the TV from HDMI to regular reception. If the HDMI ports are changed to regular TV reception they don't see the HDMI ports only the regular video ports!
Jan 01, 2013 | Televison & Video
Hdmi ports not working
If still have this set it has 3 hidden menus, one is the Option Menu which provides for hard reset of the set, it could be the answer to your problem.
Nov 23, 2012 | Mitsubishi WD-Y57 57" Projection HDTV
HDMI 1 and HDMI 2 no longer work on my TV. What can I do to repair this?
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
Oct 07, 2012 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
Hdmi port quit working, had HD sat receiver hooked to HDMI port, was working for awhile, now shows no reception?????
Need to replace the main board in your tv- it happens a lot that the hdmi stops working
Aug 19, 2009 | Televison & Video
HDMI PORT STOPPED WORKING!!
the best option here is connect via a standard PS2 avi cable or componet cable until your tech guy comes out!
Apr 30, 2009 | Televison & Video
LG 52LD550 52Inch 1080p 120Hz LCD HDTV Black 52 in TV Logo
44 people viewed this question
