Question about NEC NP400 Projector
Np400 4 status blinks - NEC NP400 Projector
Status light blinking
Sometimes the fan overheats. Pull the power plug out of the back for about 15 - 20 minutes. Then plug it back in. 95% of the time that will solve the blinking status light problem.
Feb 20, 2013 | NEC NP2000 Multimedia Projector
Should the status light be blinking?
you should call the wireless manager.
good luck.
Jul 26, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Status Lights Blinking
status lights blinking is trying to tell you something in the dishwasher is bad,go to your owners manual to see the fault codes first,then you can try turning the breaker off 30 seconds an on to see if it resets its self,if that does not work i think you might have a bad mother board,thanks-mike
May 27, 2008 | Kenmore 16079 Built-in Dishwasher
Status indicator blinks RED, not starting.
There are different rates at which the status light will blink to indicate various errors. See manual (link below) page 49 http://www.support.nec-display.com/dl_service/data/user_manual/ENGLISH/VT37/vt37_manual_e.pdf
Jul 29, 2007 | NEC VT37 Multimedia Projector
NEC NP400 Projector Logo
61 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
