Question about Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994
Wiper motor relay 2005 VW jetta location - Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994
2006 vw jetta wiper problem
check in hand book for relay position
Dec 06, 2015 | 2006 Volkswagen Jetta
2006 vw jetta wiper still not working after changing the wiper motor and wiper switch ? help
Did you check the fuse? Have power at the plug? could be a bad ground.
Dec 06, 2015 | Evan Cars & Trucks
2000 vw jetta wipers move just a little bit on the window is the relay bad or is the motor bad
Sounds more like it would be the wiper motor. If it was the relay they wouldnt move at all.
Sep 07, 2011 | 2000 Volkswagen Jetta TDI
Windshield wipers on 2007 VW jetta not swiping
wiper gears may be broken, got to junk yard and buy motor and gear assembly for windshield wipers, should only take an hour to change out.
Feb 15, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
2000 VW jetta VR6 windshield wipers wont work
first try the fues box see if you have a blown fues, next if you put your wipers on can you hear the motor running for them? if you can the linkage has poped off from the motor, its a bit awkward to get it back on and no gaurentee that it will saty on, you might have to replace linkage, or, it might be the cogs on the actual wiper arms have splayed and are now smooth so they dont grip to move, you can take them off by the nut on the arm , get a can (coke can or simular) cut a rectangle out of it the hight and width if the cog, rap it round the cog, (make sure it does not overlap on the ends) and force the arm back into place and then do the nut up, this is just a short quick fix if that is the case you will have to replace the motor, also you can check the relay to the motor in the fues box, give it a tap a couple of times it might work again if not replace it...hope you find these sugestions helpful
Feb 08, 2010 | 2000 Volkswagen Jetta TDI
2005 jetta wiper motor not working. Washers not
central locking relay its conected to all these could be the culprit
Dec 16, 2009 | 2000 Volkswagen Jetta TDI
Wipers not working at all and the fuse is ok on my vw jetta
Unplug wires at the motor.Then with the wipers switched on check for a 12 volt reading.If you are getting 12 volts then your wiper motor needs replacing If your not getting 12 volts then the switch is faulty replace it.Good luck.
Aug 02, 2009 | 1991 Chevrolet S-10
Where is the wcm relay located on a 1994 VW
ECM IS UNDER DRIP TRAY BETWEEN ENGINE AND PASSENGER WIPER.
Jun 16, 2009 | 1994 Volkswagen Jetta
Steps for replacing wiper motor for 1998 VW Jetta 4 cyl.
remove wipers. remove plastic covering by loosening plastic screws first. unplug wiper motor wires. there are about three 10mm nuts at the motor location and you also have to unscrew the big nuts that were below the wipers when you unscrewed them. replacement is reversal.
Mar 23, 2009 | 1998 Volkswagen Jetta
Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994 Logo
73 people viewed this question
Top Mopar Performance Clothing Accessories Experts
Da Doc
ray gallant
Are you a Mopar Performance Clothing Accessory Expert? Answer questions, earn points and help others
