Question about Ithaca iTherm 280 Thermal Printer
How to reload paper - Ithaca iTherm 280 Thermal Printer
No paper fed reload paper
The paper detect sensor could have dirt in it. Blow canned air directly on the sensor and try again. Asides from the sensor being bad the actuator for the sensor could be broken.
Sep 11, 2009 | Office Equipment & Supplies
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
"reload paper" message
Lower paper sensor was completely dusty. Just blowed it and it works.
Apr 15, 2009 | Epson Stylus Pro 7600 InkJet Printer
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
9600 keeps telling me to RELOAD paper
just flick the paper lever up and down. dont fiddle
Jan 16, 2009 | Epson Stylus Pro 9600 InkJet Printer
Check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Jun 30, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Reload paper error
Listen for the paper tray is popping up when you push it in.
Remove the paper tray completly and look for paper in the cavity.
Jun 24, 2008 | Brother MFC-8220 Fax
Ithaca iTherm 280 Thermal Printer Logo
32 people viewed this question
Top Ithaca Office Equipment & Supplies Experts
Alan Rothery
Are you an Ithaca Office Equipment and Supply Expert? Answer questions, earn points and help others
