Question about Hammering
Brushes for belt sander
Brushes
  • 22 Answers
SOURCE: belt sander parts
try going to lowes
Posted on Apr 03, 2009
  • 5603 Answers
SOURCE: After replacing the brushes in my old Rockwell
Did you dress the brushes to the contour of the commutator?
You wrap the commutator with fine sandpaper and rotate under the brushes till the curve conforms.
If this does not reduce the arcing, then you may have an armature with a bad winding.
Posted on Sep 30, 2009
Testimonial: "Sounds logical. I'll try it."
agent91
  • 2100 Answers
SOURCE: I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
Posted on May 25, 2010
Testimonial: "Thank you for your help, now all I need to find is my manuel to break it down."
  • 885 Answers
SOURCE: 9040 belt sander keeps burning out the carbon brushes
If you are burning or wearing out brushes within days, you may have a problem with the commutator on the armature. The copper ring where the brushes make contact had to be absolutely smooth. If it is pitted or one of the contacts is bent upwards, it will eat brushes as fast as you are indicating. If it is dirty or pitted it may be repairable on a lathe with an armature resurfacing stone. If one or more of the contacts are damaged or bent you will have to replace the armature, they are very rarely repairable.
Posted on Jan 30, 2012
  • 5 Answers
SOURCE: Brushes on my sander are wearing out within 10mins
The part number for replacement brushes for this sander is #CB-303 and they are $2.70 each or less depending on how many you order. There is a minimum order amount. We stand behind our products. If ours wear excessively there is probably a problem with the commutator in the tool. Ohio Carbon Industries is a manufacturer and distributor of carbon brushes for nearly all electric motors. Call our sales dept. at 419-496-4456 or email them at sales@ohiocarbon.com. Visit our website at www.ohiocarbon.com
Posted on Mar 20, 2012
How to change brushes on a Black & Decker 7450 belt sander
You will need to take the right hand cover off of the tool, You might be able to access the brushed by removing the smaller motor cover. The design changed several times on this sander. I have included an image showing the brush locations..
Mar 24, 2017 | Sander Tools & Hardware - Others
Durabuilt 3"X21" Belts Sander Brushes. Question: Should I replace brushes or buy new sander?
If the sander is otherwise in good shape, and hasn't been abused, I'd replace the brushes.
Jul 11, 2014 | Greenfield Industries Measuring Tools &...
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
Ihave replaced the brushes on my 9404 belt sander and it is running as if it still needs the brushes changing. Any ideaS?
If there is excess sparking from the brushes then the armature is shorted. Also a bad field can make a tool run slow.
Aug 07, 2012 | Makita 9404 4'' x 24'' Belt Sander
Jan 30, 2012 | Makita 9404 4'' x 24'' Belt Sander
The belt on the sander doesn't turn. The sander has power when plugged in and the motor runs when you press the button. But the Belt and track don't turn.
Likely the gear belt that drives the drive rollaer has failed. Either it is totally gone or the teeth in a spot have been destroyed and the motor is just spinning the sprocket in the belt. The belt is about 1/2 inch wide and is covered by a belt guard.
Jun 13, 2010 | Makita 3 x 24" Belt Sander
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
the armature could be the problem, when you replace them do you notice a lot of arcing around the commutator, it might be bad or just need to have the surface cleaned. let me know.
Jan 22, 2010 | Makita 9404 4'' x 24'' Belt Sander
Belt sander
You're plugged in to a dead outlet, OR the rotor brushes are not in contact with the rotor, OR the power cord is partially severed,
Jan 06, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Hammering Logo
78 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
