Question about LG Xpression MobiPhone - Red at&t
My texting is messed up.
My texting used to be normal. Its been almost a week but my phone's texting is messed up. Instead of the regular screen it only a black screen with the other person that you texted. It also has the date and time. In between those is their text. Also i need to click this reply button near the bottom in order to text them back. Even after i sent it back, my text doesn't show it. It only shows up in the outbox. Finally every single text comes into my inbox as a seperate text
    Master:
  • LG Master
  • 515 Answers
It means your msg, not deliver or not sent so you have to reset your massage setting
Posted on Jun 10, 2017
5 Suggested Answers
SOURCE: cannot send texts as phone
Make sure all your contacts are on the Sim card and any data in phone memory is saved. Then go to the settings section and use the "RESET ALL" function to reset the phone.
This solved the same problem on my KF300, but it did delete all my contacts, hense the warning above
Ian
Posted on Nov 07, 2009
  • 6 Answers
SOURCE: my lg neon will not let me set my text messages
you have to wait till the end of messages then it lets u add contacts
Posted on Nov 29, 2009
SOURCE: inbox glitch on lg ks360
I have this same problem, unfortunatly I do not have a solution but I hope someone will, I took it back to the store and he said i needed to deleted messages from my outbox etc so it wasnt full, this solved my problem for a while but now it is reucurring every time my phone turns on and off even without any messages in my inbox. I would leave my phone on as to avoid the problem but it keep turning itself off also. Very frustrating.
Posted on Feb 24, 2010
bobager
SOURCE: my lg enlighten will not let me receive a text
Mine is doing the same! Did you ever find a way to fix it? If so please let me know at bobager@ymail.com
Posted on Sep 22, 2012
I just recently got my lg ks360. But every time i slide my phone to make a text my phone always happen to freeze.can any one help me so that this wont happen again. It is really bugging me.
Remove your memory card, if it stops freezing, the card's your problem. Either the card is not compatible (more than 4gb or SDHC instead of SD), or the phone is referring to the card during normal operations eg wallpaper, ringtones etc. Copy these "operational" files to the phone and only use the card for storage of pictures, music etc, but not for anything the phone uses regularly. If the problem persists after you've taken the card out, sorry can't help...
Jul 06, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Screen won't rotate when I slide it open to text
i had the same problem...this is what you do. u check to see if you have a magnetic phone case or if ur phone has been exposed to any magnets. idk why but magnets mess up the screen rotation. all u have to do is take a magnet and pass over the phone once and it should go back to normal. but dont ever expose the phone to any magnets.
hope this helps .
thanks.
Jun 21, 2010 | Cell Phones
LG env2 will not save text messages
This happened to me. My problem was that i had a memory card, and i accidently put the save options for my pictures to my phone memory instead of to card memory. So it messed up my phone.
May 30, 2009 | Verizon Communications enV2 Cellular Phone
My texting on a weird setting please read!
did you try going into options in the messaging menu. you should be able to turn off the predictive txting. otherwise look through your settings. Honestly you may have to just play around with it for a bit to find the setting. I had this issue with my Razor VE20 I ended up getting rid of it for a LG. Best of luck.
May 28, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Picture messages
Go to Menu>Settings>Restore factory settings
Jun 22, 2008 | Nokia 6133 Cellular Phone
MY E815 screen has weird signs
Check this link to see info about your phone.
Apr 25, 2008 | Motorola Mobility E815
When a text msg comes in it plays a mp3 instead of the normal text sound.
yes there is just go back into the setup and look at what you have as your text msg alert and change it.
Feb 01, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Phone Sending MMS Messages as Default
The phone allocates a certain amount of storage for messages on a whole. Even though there may still show space available for text messages, you have hit an invisible "limit" and the phone is now defaulting to MMS messages because there is "room" there. Delete a fair amount of messages and you should be able to start sending regular text's again.
Oct 02, 2007 | Motorola Mobility RAZR V3m Cellular Phone
LG Xpression MobiPhone - Red at&t Logo
27 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
