We have a Curtis LCD4680A/Aw televison and am having trouble connecting headphones because we don't see an identifiable Audio Out Jack! Does the Curtis LCD televison have an audio out jack or what por
None of the ports in the Instruction Manual are labeled 'AudioOut'. We formerly had the headphones connected thru the cable box but are cutting the cord and using just the television with antenna and Rocu. My husband prefers the headphones, using them for over 10 years to help him clearly hear what is said. Even if the volume is up it's still not clear. The headphones are the only option for him. Found an article on Web about 3.5mm female jack to stereo RCA "Y" adapter. Does anyone know if this is accurate information for using headphones? Thanks so much
  • 10 Answers
Did not work..
Posted on Mar 12, 2008
SOURCE: Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Posted on Dec 26, 2008
  • 265 Answers
SOURCE: proper audio cable to hook up PC (headphone jack) to 50 in plasma
Hi there..
you just need a 3.5mm standard audio cable, from the green audio port out the back of the computer to the audio in port in the TV :)
can get them from ebay for 99p :)
hope this helps
Posted on Apr 06, 2009
  • 87 Answers
SOURCE: No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Posted on Apr 20, 2009
SOURCE: I have a Toshiba 46XV550 LCD TV. It has a
I went to the local electronics store and bought one 2xRCA sockets-3.5mm stereo socket splitter and 2 RCA joiner/couplers and plugged that into the monitor audio plugs at the back of the TV. Works great for a total of $12.00.
Posted on Sep 15, 2009
How do i connect my stereo system's speakers to my televison
audio out tv to stereo audio in or aux
tv out (rca or headphone jack)
audio in on stereo or aux in
May 28, 2016 | home Audio Players & Recorders
GE audio/video switch AV93294 has what appears to be a adapter port on front , no voltage given. Says audio output. Please explain
As the label says, it's an audio output. The audio from whichever source you have selected appears at that jack so you can plug in something like a pair of headphones or the cable to a wireless headphone transmitter. If you don't have anything to connect there, don't worry about it. It's a convenience, but you don't need to use it.
Aug 14, 2011 | Audio Players & Recorders
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
#1. Where can I get a free copy of the Manual for RCAWHP150C Wireless Headphones; #2. How can I us with TV that has not headphone connection?
for Q1 try this one
for Q2 this one should do the trick
Mini StereoJack to Left and Right RCA Plugs
hope that helps...
Aug 07, 2011 | RCA WHP150C Consumer Headphones
My garmin 660 won't transmit audio through speakers or fm transmit. I go to audio output and it says that "Audio output can not be changed when using headphones" I can use it with headphones...
You have a problem with the headphone jack. Please see this link and read the section about BROKEN HEADPHONE JACK
Because there is a broken connection, your Nuvi thinks there are headphones connected at all times, so you wont be allowed to change the sound options. I've repaired this problem many times. Don't try it yourself, you risk damaging your Nuvi beyond repair.
- Jim
Jul 19, 2011 | Garmin Nuvi 660 GPS Receiver
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Jun 10, 2011 | Acoustic Research AW-772 Headphones
Connecting Logitech speakers to Sylvania TV
"All the audio inputs in the tv dont fit with the cable from the speakers." You would be connecting the speakers to an audio output on the TV.
Mar 18, 2017 | Sylvania LC320SS9 32 in. LCD TV
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Sound from only one headphone
I purchased an AW 771 set in "as is" condition which on arrival produced output only from one side. Repair was effected by removing 8 phillips screws, 4 from each side, concealed under the ear-surrounding doughtnut-shaped cushions. To expose those screws, the ear cushions must be pushed from their center toward the outside. Black screws in back holes surrounded by black acoustically-transparent cloth does not make them obvious.
I used a volt-ohm meter to find a discontinuity at a failed solder connection. Resoldered that connection, rechecked electrical continuity to be certain all connections were good. Tested with batteries installed using an audio input. Both sides produced sound. Replaced screws and they have performed very well since then.
I hope this Model AW771 experience is helpful in restoring your AW-721 to working order.
Oct 25, 2007 | Acoustic Research AW-721 Consumer...
Televison & Video Logo
Top Televison & Video Experts
