Question about Car Audio & Video
Nd3nw52 reset Disk Eject Problem
Need to eject
If you're told you can't eject a disk, try the following suggestions..
f you're trying to eject an external disk:
  • Choose Apple menu > Log Out, and then log in again. Try to eject the disk again.
  • If you still can't eject the disk, choose Apple menu > Shut Down. Disconnect the disk from your computer, and then start up your computer again.
    f you're trying to eject a CD or DVD:
    • Choose Apple menu > Log Out, and then log in again. Try to eject the disc again.
    • If you still can't eject the CD or DVD, choose Apple menu > Restart. While your computer restarts, hold down the mouse button or trackpad button until the disc is ejected.
      If you're trying to eject a network disk:
      Choose Apple menu > Log Out, and then log in again. The network disk should be gone.
Jun 11, 2012 | Apple Computers & Internet
Cd stuck
Did you try resetting it?
Jun 04, 2008 | Bose & Wave& Music System
Dvd plays dvd but door will not open what do i do?
Pull the power plug, then plug it back in. That should reset it and allow the disk to eject. It can take up to half a minute to eject a disk on a DVD player, so be patient.
Jul 05, 2011 | Sony DVP-SR101P DVD Player
When i turn system on and hit reset red light comes on and system won't eject disk
well the same thing happened with mine only it was the RROD but in order to get the disk out
1. turn off the switch in the back
2. hold the power button down AND the eject button at the same time
3. and while you are doing that reach around to the back of the system and turn the switch back wait 1 second and the fans will kick on
THE DISK SHOULD COME OUT IF NOT PRESS THE EJECT BUTTON
HOPE THIS CAN HELP!!
Jul 15, 2010 | Sony Playstation 3 (PS3) Console
DVD stuck inside sony dav-sc5. Pressed the eject button and nothing happened. Did the usual turn it off and on again and it started to read the disk but then nothing happened. Tried to eject it and nothing...
Have you tried to unplug the unit for 1 or 2 minutes to see if it can reset the computer chip inside of the DVD player?
I have had great sucess with this trick.
I hope that this helps you out of this situation.
asnowman
Feb 08, 2010 | Sony DAV-SC5 System
OK.. I could not get a disk to eject from my wii console. I tried unplugging it and slapping it on the side.. I also found this site trying to figure out what i can do.. I took some of yalls advice on...
Oh my God ;-) Isn't it funny sometimes when you don't notice simple things, happens all the time.
I one time spent 30mins trying to turn on a PC, to only notice I was pressing the "reset" button and not the power button!
Glad I'm not alone.
Jan 03, 2010 | Nintendo Wii Console
Advent ADV35 dvd player disk wouldn't eject, now won't load
Hello there:
I would first check to see if eye is not scratched or dirty and clean it if nesassary..
If you unplug the unit for a few minutes it should reset it's self.ok
and good luck on the drive i am a retired navy vet and know what you are going thru with the move.
best regards michael
(USN RETIRED)
Aug 25, 2009 | Audiovox Car Audio & Video
2005 malibu cd player says check disk wont eject
Unfortunately yes. This is a very common problem.
Jun 22, 2009 | 2005 Chevrolet Malibu
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Cannot Eject DVD
There will be a manual eject but its slightly tricky. There will be a small hole(about 1mm diameter) near the tray where you insert the DVD. Just insert a samll pin or something into it and keep shoving it in and out by repeatedly pressing the eject button. If its just a stuck DVD then it will come out in a JIFFy. Otherwise send it for repairs as taking the unit apart might void your warranty! Good luck!
Sai.
Jun 16, 2008 | Panasonic HDC-DX1 DVD Camcorder
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
