Ricoh Aficio 150 Copier
Problem for Ricoh Aficio 150 Copier
TROUBLESHOOTING ERROR CODE SC320
By joenerthan on Jun 19, 2009
COPIER TYPE: RICOH AFICIO # H43 10200342
Best Solution
posted on Jun 19, 2009
Helpful)
Touch2Heaven
Rank: Wiz
Rating: 76%, 79 votes
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 08, 2009
Somewhat Helpful)
Bantams
Rank: Master
Rating: 86%, 13 votes
its a common fault after a few thousands of copies the laser motor packs in you need a new one
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 150 Copier
Questions and Unsolved Problems for Ricoh Aficio 150 Copier
Do you recommend Ricoh Aficio 150 Copier?
Answer
Answer
Our intellifax 4100 fax machine sends faxes but does not receive them. It has a dedicated phone... (More)
Answer
cannon f149200 says toner not set properly,yet we reset it a hundred times.Put a new toner in and... (More)
Answer
my iR 5000 had an error code E000004-0000. solve this
Answer
Unable to send Fax "cannot send because memory is full" How do I clear memory?
Answer
Forgot the password to our old Konica 3135. How can I reset this? Looked all over the motherboard... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio 150 Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
