Question about Dryers
Lasko fan was plugged into wrong voltage . stopped working
Fan was plugged into wrong voltage. Stopped working
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Posted on Sep 04, 2008
  • 3 Answers
SOURCE: Lasko 2554 Wind Tower Fan
I have a Lasko HVB, but this might apply to your fan:
Without taking the thing totally apart, here's an idea you can try: The power cord on some models (like mine) has a "warning" tag. I had the damn thing all apart when I noticed this. (Well, who reads 'em??) Seems like there's a mini-fuse in the PLUG itself that, when it blows, there's nothing you can do about it except send it for repair to a factory authorized yadda yadda yadda. Who's going to do that??
If you plug in and NOTHING HAPPENS, here's what might turn out to be an cheap and easy fix: cut off a few inches of the plug end of the cord and go buy another plug at Ace. Heavy duty might be appropriate: don't think I'd want a lamp plug on this baby. Get one that's easy to install. Bring the cut off piece and they'll help you find exactly what you want.
If you want to open it up, there's a screw behind the Lasko medallion, remove that and you can snap out the grille. You can see where the cord comes in from the back of the blower housing. Test the line voltage. If you're not getting about 120VAC, it's the plug.
If that's not it, IMHO, without some knowledge or a schematic, you're screwed. That'd be me. It wasn't the plug.
-Chuck
Posted on Sep 22, 2008
  • 9 Answers
SOURCE: my Lasko 40" Tower fan stopped working.
ok everybody who has this model #2534 it seems that the motor has gone bad so you have two choices you eighter find the recipt where you brought it from but there a catch 1 year from the day you brought it from. second choice buy a new motor. third choice buy a new one. sorry!
Posted on May 18, 2009
  • 691 Answers
SOURCE: My Lasko Pedestal fan just stopped working completely
Its probably something simple, plug it into another outlet and make sure that outlet work also, if that dont work it will be in the control switch and i doubt the motor is burnt up. You can take srew driver and open up the control cover to see if there a fuse and check the wiring connection from the outlet to the control switch and make sure the fan is unplug before you open up the cover. Jiggle the wire inside the control unit than press and play with the button couple of time and plug it back into the outlet and see that will work. if not than have somone test the the motor with a volt meter making sure the motor still good. I believe it be more likely in the control swith unit. hope that work for ya
Posted on Jul 10, 2009
  • 347 Answers
SOURCE: Lasko fan will not ocillate
check the oscillating gears usually made of plastic
Posted on Aug 30, 2009
I need a remote for my lasko floor fan mine stopped working
contact LASKO we do not source parts hereon fixya
Apr 02, 2018 | Lasko Dryers
Osilating stopped on lasko 2554 fan
Lasko's are good for stripping the gear in the base that makes it oscillate. If it's still under warranty, they will send you a new fan.
Jul 28, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
My lasko tower fan works bot stopped ossilating
Well could be several things that could make it not oscillate. Motor is bad, stripped out teeth or gear slipping on motor. You would have to take it apart and see if you are even getting power to the motor.
May 28, 2015 | Lasko Dryers
My lasko fan stopped blowing air
The rotation gears have gotten clogged up, take it apart and put some grease or oil in the rotation parts/gears and work it in until it spins freely. Will work like a charge afterward. I had to do it once myself already.
Sep 24, 2010 | Lasko 2530 Elite WindTower Fan
Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Nov 08, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Aug 28, 2009 | Lasko High Velocity Space-Saving Blower...
My lasko fan stopped working after a power outage. the motor hums but blades dont spin
check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
Aug 26, 2009 | Lasko 3135 Stand (Pedestal) Fan
Problem with a Lasko 3440 Floor/Box Fan.
light is on ,but there is no movement from the fan. I think I need a fan motor.Lasko 20" fan motor part #3440.
Mar 30, 2009 | Lasko 3440 Wind Tunnel Floor / Box Fan
-Chuck
Jun 08, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
LASKO fan problem
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
Dryers Logo
46 people viewed this question
Top Dryers Experts
