Question about Cell Phones
Yeasu Ft215a keypad inop
I have two units both have the same failure, the keypad doesn't do anything, will not even stat the unlocking sequence. I replaced the memory cell in one with no change. All else appears to work just fine. Ie., vol, squelch, transmit, etc. I have the manual and schematics. I've used contact cleaner on the ribbon connectors, likewise, no change. An ideas from someone who has had similar problems? This old workhorse has served long and I don't want to trash it!
  • 33 Answers
SOURCE: keypad problem with samsung d900.
Press all of side buttons. Are they OK? Many times they are stacked in and are blocking others. Try to press them a bit harder than usual. If the problem is still present, send it to the service.
Posted on Sep 29, 2007
  • 44 Answers
SOURCE: G600 keypad not working
Take your phone to your local market & ask any market phone repair vendor to fit a new keepad membrane, if this doesn't work it's trobably irriparable damage either caused by water or the fumes of some kind of solvent for example super glue.
Posted on Dec 22, 2008
  • 1447 Answers
It would best if you return the phone from where you bought it since your are having multiple issues with a brand new phone, sounds unlikely so ask for a replacement.
Thanks for using fixya
Posted on May 11, 2009
SOURCE: nokia 6600 startup failure
I have the 6600, last week the mobile couldnt work. phone registration failed contact retailer message displays. i have many messages in that mobile. i contacted the retailer, but the retailer told only solution is flashing the mobile. shall i get back my messages in that mobiles please help me
Posted on Feb 01, 2010
SOURCE: how do i keypad lock manual my cell phone KA08
Select Meeting profile an turn on sound in it's settings. on my mini ka08 n003 it's working.
Posted on Mar 06, 2010
2003 grand marquis ls door locks and trunk not working
Hi, sounds like you may have lost power. Check your fuses, remember, you have fuses in the cab and under the hood. Hope that helps
Oct 10, 2017 | Cars & Trucks
Blower fan continually runs
It may be but the fan control may be set to turn off at to high a temp, or theres a short between ;r; and g at the stat or furnace or sequencer, IF it runs through it. A limit or rollout switch may have failed but this will keep the unit from firering. Check for a manual blower switch that may be on. At stat it should be at auto and alsso at the fan control. A stuck relay is always possible,
Mar 08, 2015 | Coleman Home Electric Furnace Eb15b/Eb15d
Yeasu Ft215a keypad doesn't work
Call a technician to check it for you please
Apr 18, 2014 | Sharp XE-A101 Cash Register
TREADCLIMBER tc5000 error code e5_5
see the steps and fix it. God bless you
Error 5
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
Nov 18, 2012 | Exercise & Fitness
How do i un freeze my nokia twist
  1. Make sure that the keys are actually locked. If you attempt to unlock a keypad that is not locked, nothing will happen. Look on the phone's screen for the key icon that indicates the keypad is locked. If you try to press any of the keys and the word "Unlock" appears on the screen, your keypad is definitely locked. If you do not see the indicator but are unable to use the keypad of your Nokia 6085, your battery could be dead, so try recharging it and then see if the keypad works.
  2. Enter the unlock sequence. If the key indicator appears on your screen, you need to enter a simple sequence of keys to get the keypad working again. For the Nokia 6085, select Unlock and then quickly press the * key. If you wait more than 1.5 seconds to press the * key after selecting Unlock, it will not unfreeze the keys so make sure you enter the sequence very quickly.
  3. Turn off the automatic keyguard. If you are tired of having to unfreeze the keys every time you want to make a call, you can program the Nokia 6085 to always remain unlocked. In the menu, go to Settings, then select Phone, then select Automatic Keyguard and choose Off.
Mar 01, 2012 | Nokia Cell Phones
How can i unlock my nokia 5800 . i slide the keypad down and it says ''slide keypad down to unlock '' i even took the memory card and battery out but still doesn't work ?
In Nokia 5800 there is slider key on left side wall of you handset.Press and drag it to down ward once to Unlock and to Lock Drag it once again .
Aug 16, 2011 | Nokia 5800 XpressMusic Smartphone
My Luxpro psp511 ca is locked and I don't know how
TO LOCK THE KEYPAD: Start with the System Mode switch in either the
HEAT or COOL positions, and the Set Slide switch in the RUN position.
Perform a single press of each button, in the following sequence: NEXT,
TO UNLOCK THE KEYPAD: Start with the System Mode switch in either
the HEAT or COOL positions, and the Set Slide switch in the RUN position.
NEXT, NEXT, HOLD. The padlock should no longer be present, with the
thermostat now unlocked. If the padlock is still on the screen, please try
to enter the 4-button sequence again.
Jun 01, 2011 | Heating & Cooling
Pilot lamp is lit but the Cozy Thermostat will not operate the furnace valve to turn on. Is there a test to check whether it is the thermostat or valve inop?
pull the 2 wires off of stat and twist together if unit come on its the stat if not go to the gas valve and jump out to see if the valve will come, the 2 th terminals.
Oct 31, 2010 | Cozy (W352E) Heater
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Feb 28, 2009 | Heating & Cooling
Intertherm air conditioner split unit
you need to know if the heat strips are energized by a contactor or relay as opposed to a heat sequencer. as a general rule the contactor or relay clicks shut as soon as a call for heat is made and the fan is energized by the stat at the same time . instant heat strips and instant fan. if the heat strips have a sequencer it may take up to 90 seconds or so before the sequencer heats up then clicks and puts power to the strips and the fan motor at the same time. the high voltage usually feeds from the strip side of the sequencer through the normally closed side of the fan relay. if you changed the stat and didn't switch the fan setting switch to elec, the fan will not be energized by the stat. if it is in the gas position, you have told it that the sequencer is bringing on the fan and of course it won' t if you don't have a sequencer.. this is tough stuff to trace even for an experienced pro cause its interconnected so dual fan speeds can't be energized at the same time. most likely you have a new digital stat that was not programmed correctly to bring fan on in heat. good luck
Nov 12, 2008 | Intertherm Heating & Cooling
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
