Question about Singer 3321 Talent Sewing Machine
Insert the bobbin case
Reinsert bobbin case
3 Suggested Answers
SOURCE: The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Posted on Jan 28, 2012
  • 1860 Answers
have you tried a new bobbin, some machines only take certain bobbins..
Posted on May 19, 2016
Reinsert the bobbin case in Viking 500
after removing the needleplate and gray bobbincase retainer, manually rotate the handlwheel so that the tip of the hook is between 11oclock and 10oclock. carefully insert the bobbincase into the hook assembly so that the gap in the bobbincase is centered below the feeddogs. manually rotate the handwheel slowly to confirm that the bobbincase is fully seated into the hook assembly. reinstall the gray retainer and then the needleplate. again manually rotate the handwheel to confirm that everything is seated correctly.
Feb 11, 2015 | Husqvarna Sewing Machines
How do Iinstall the Bobbin holder in na Singer tiny taylor machine?
I"m assuming that you are asking how to reinsert the bobbin case, rather than the bobbin itself. If you don't have your user's manual, you can download it free at the Singer website. When you do, look on page 19; it has exact directions and an illustration there regarding how to reinsert the bobbin case.
Oct 06, 2014 | Singer Tiny Tailor TT700
How can I replace bobbin case on Singer Inspiration 4220
Download the instruction manual free from the Singer Sewing Machine site, and go to page 62. It will show you how to reinsert your bobbin case.
The flat part goes UNDER the needle; there is a projection on the right side of the case towards the bottom that must rest against a silver part that is actually a cushion spring and prevents it from spinning. It's pictured in the manual.
It's helpful when reinserting it to insert it slightly clockwise of where it should go--that is, placing the flat part slightly to the right, then twisting it counterclockwise into the correct position, with the case's projecting resting against the spring.
Jun 21, 2014 | Singer 7442 Mechanical Sewing Machine
Bobbin case inserting wrong
hi, Can i ask what model Pfaff it is ?
Regards
Rob
www.electronicrepairs.co
Dec 29, 2013 | PfaFF Sewing Machines
I suspect the "housing" you refer to is not seated completely. Be sure to wiggle it until it slips into place. Once it is seated, the bobbin case should seat firmly as well.
May 02, 2017 | PfaFF Sewing Machines
I have a necchi sewing machine. How and where do you insert the bobbin in model 525fa
if you have a snap in sewing table remove it first
at the bottom in front of the needle plate area is a bobbin case door
when you open it there is the bobbin case & also should be the feed dogs
always keep the bobbin area clean of lint or loose threads
take note of how the bobbin case is inserted in the bobbin area,, see where the thread tail is at on the bobbin case
then make sure the bobbin is wound correctly or it can cause sewing problems
reinsert the bobbin into the bobbin case the same way it's removed
I also have a necchi sewing machine, the base of your is like the base of mine, if you need a picture of inserting the bobbin,, send me a comment with your email address & I will send you a picture of the threading the bobbin case & inserting it
Nov 17, 2010 | Necchi 3101 Mechanical Sewing Machine
Can't reinsert bobbin holder
You may not have the bobbin case seated properly in the bobbin well. Make sure the flat edges go underneath the metal flanges that are there to hold it in. I'm attaching photos of a similar problem I answered earlier that might help you understand how it goes in.
Below are the directions I sent with the photos...I hope this helps you! Good luck!
"This type of case can be a pain. First in photo 1, on the silver flange marked in a red circle there is a rectangular hole marked with a green circle. using a flat head screwdriver, insert into the rectangle and turn to the right. This should move the flange tongue marked with a blue circle towards the back white wall of the bobbing well. In Photo 2 take the black bobbin case and place in the bobbin well area marked with the pink spiral. Tilt the case slightly to insert the flat tongue marked with an orange X on the black bobbin case under the flange marked with an orange X in the bobbin well. Now let the black bobbin case sit in the bobbin well marked with the pink spiral. Now in Photo 3, you want to turn the black bobbin case to the right so the flat tongue marked with the orange X will go underneath the flange marked with an orange X. The other flat area marked with a purple X on the black bobbin case should line up with the purple X in the bobbin well. Once the black bobbin case is seated in, repeat the steps from Photo 1 in reverse to get the silver flange back over the bobbin case to hold it in place. I hope you can understand my directions and I hope this helps! Good Luck!"
Apr 27, 2009 | White Sewing 1521
Bobbin Case will not snap into housing
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
Oct 14, 2008 | Consew 206RB
Singer 3321 Talent Sewing Machine Logo
55 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
