Question about Pioneer Audio Players & Recorders
How to Replace belt on Pioneen turntable AL-158
3 Suggested Answers
  • 396 Answers
SOURCE: I have a 26 year
You can go to Vintage Electronics and purchase it by clicking below.
http://www.vintage-electronics.cc/JVC.html
Posted on Jul 12, 2011
STYLUSCITY
  • 271 Answers
SOURCE: need to replace the belt on my JVC AL-A95
To replacea turntable drive belt.Copyright.. Styluscity.com, JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correctoperation.
MUSIC IS LIFE, LIVE IT LOUD.Styluscity.com cansupply replacement drive belts for all turntables
Posted on Nov 03, 2011
Turntable not rotating. What should I do?
HI, lift the platter off and check belt. If it is broken or stretched you will need to replace it. To test belt for over stretch simply place it on the platter pulley then flip platter over the right way up. If belt stays put it is ok, if it falls off it needs replacing. Keep em spinnin, John Stylus City.
Jun 20, 2014 | JVC AL A158BK Turntable
Need to replace the belt on my JVC AL-A95 turntable
Oct 08, 2011 | JVC AL A158BK Turntable
Haven't used the turntable in years. Went to use it today and the turntable doesn't begin turning when the arm is lifted. Everything else works. Thanks, Al
If this is a belt driven turntable, then you have to replace the belt, as this units gets old the belts loosen up as well.
Aug 20, 2010 | Crosley CR74 Turntable
How do I change a drive belt on my JVC L-A11 Turntable
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Dec 15, 2009 | JVC AL A158BK Turntable
How to replace the belt on jvc l-f130 turntable
You will have to lift the platter section off the unit itself. Check for the spindle motor turing the table and lay the belt out around the spindle motor. Refit the platter and work the belt around the inside of the platter through the two large holes in the tray.
Nov 22, 2009 | JVC AL A158BK Turntable
Jvc turntable
hi, please check first your fuse inside your turntable, replace it if possible
Apr 04, 2009 | JVC AL A158BK Turntable
How do you reinstall drive belt for JVC AL A155 model turntable?
http://www.archive.org/details/Turntable_Belt_Installation
archive.org above has a video about how to do it. The general method shown applies to just about any turntable including your JVC
Feb 10, 2009 | JVC AL A158BK Turntable
How to replace belt in jvc turntable
I just got a JVC turntable from a thrift shop today and as soon as I got it home the belt broke. I had a replacement but couldn't figure out how to install it. After taking off the back, which is about 4 screws plus the 4 feet and the grounding screw, I saw a very tiny set screw on the post where the spindle obviously is. I removed this and the table came right off so I could replace the belt. I couldn't get the tiny set screw back but figured I didn't need it and if I ever have to replace another belt, I won't have to take the back off anyway. I hope this helps.
Jan 02, 2008 | Audio Players & Recorders
29 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
