Question about Polaroid Televison & Video
Polaroid D14 error code
Will not allow me to choose the Channel option in the menu.
4 Suggested Answers
  • 3 Answers
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Posted on Aug 20, 2006
  • 375 Answers
SOURCE: not letting me choose certain options in my menu list
do you have cc option on the remote hand unit,do you still have the book .
Posted on Aug 30, 2007
  • 6 Answers
SOURCE: Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
TV power button on my RCA True Flat 27" screen TV
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Jun 17, 2013 | Televison & Video
Why can't I find the codes for DirectTV remote?
The DirectTV remote should have the option to
scan for the code check the instructions for
the automatic scan method most likely you
turn on the tv, dvd/vcr keep pressing button
until channel changes or set turns off which
ever button you use if you dont have the
instructions try this address
http://www.satex.com/directv/remote_codes.html
Nov 22, 2007 | Polaroid FLM-3232 Television
Password forgotten control
If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. More than Nine and half Lakh viewers cannot be wrong.
May 18, 2013 | RCA E13320 13" TV
How to unlock childs security?
Instructions
Jun 28, 2012 | Sansui DTV3200 32" TV
I have removed all cable boxes from my home. I cannot get the tv remote to change channels. I was told by the cable tech that I needed to do a channel search. How do I do that?
Which specific model do you have? The menus may depend on your model. Are you using the original TV remote or a different remote? If you do not have the TV remote, try the buttons on the TV. Use the channel up/down buttons to navigate through the menu items and the volume up button to enter a sub-menu.
Try Menu and locate the Channel sub-menu. Then make sure that the antenna Air/Cable item is set correctly. Then the Channel Search option is on the next line. This is the method for the LCD2050. For the TTM2901L, you need the same Channel sub-menu but the channel search is called "Auto Program".
A number of other manuals for Polaroid TVs are available here: http://www.polaroid-tv.com/polaroid-lcd-tv/manual/ .
I hope this helps. If you add a comment with your model number, I'll be glad to provide additional help. (Note: without the model, I can't be sure which tuners (NTSC - analog OTA or cable, ATSC - digital OTA, or QAM - digital cable) are in your TV. This may change whether you can receive any stations without the cable boxes.)
Jan 25, 2012 | Polaroid Televison & Video
Etting error message 50300
Error code 50300 implies that your internet connection settings aren't right.
Nintendo DS:
On your DS you'll want to navigate to System Settings > Internet (it's on page 3) > Connection Settings. Select an empty connection to use (it'll say "None"). Select the "Search for an Access Point" option; it'll show you all available networks in range. Select yours and provide any security key/password if needed.
Here's the specific support page for error code 50300.
Here's a detailed guide on how to set up an internet connection.
Wii:
From the main channel menu on the Wii, hit the Wii button. Then navigate to Wii Settings > Internet (page 2). Select an empty connection, choose your connection type and then follow the on-screen instructions. You should first try choosing "Automatic" or "Auto-Detect" whenever possible. If that doesn't work, try using Manual settings.
Hope this solves your issue!
Mar 25, 2011 | Nintendo Video Game Consoles & Games
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Change the time on DV 1130
Manual Clock Set
1 Press MENU to display the MAIN menu.
2 Use up/down arrors to choose the CLOCK menu.
Press ENTER and the CLOCK menu will appear.
3 Use left/right arrors to choose the MONTH option.
4 Use down arrow to choose the DAY option.
Use
L/R arrors to choose the date.
The day of the week will display automatically.
5 Use down arror to choose the YEAR option.
Use
L/R arrow to choose the year.
6 Use down arror to choose the TIME option.
Use L/R arrow
to choose the time.
Press and hold L or R arrow
to advance the clock
continuously.
7 Use down arrow to choose the DAYLIGHT SAVINGS
option.
Use L
or R arrow to choose AUTO, ON, or OFF.
If you choose AUTO, the VCR sets the clock using the
DST information broadcast in the signal (channel).
If you choose ON, the VCR adjusts the clock for Daylight
Saving Time automatically.
Mar 23, 2009 | GoVideo DV1130 DVD Player/VCR
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
Need code
I called one-for-all and got a repair number and then sent the remote to them to have the codes added.
Dec 13, 2007 | One For All URC4220 Remote Control
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
