Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Lettering and some images have cloudyness to them. I adjusted the convergence settings and the red and blue but its still cloudy. Bulb dusty?
  • Panasonic Master
  • 5,138 Answers
Clean your mirror and all 3 tube lenses.
Posted on Jun 19, 2009
Colour and shade blue highlights lettering captions are double, the picture is destorted and happend over night.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 19, 2011 | Hitachi 53UDX10B 53" Rear Projection...
THE PICTURE ON MY TV IS SHOWING A YELLOW SHADOW ON ON SIDE MORE & A BLUE SHADOW ON THE OTHER. IS THIS A BULB PROBLEM?
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 28, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Picture very dark. I think I need to replace bulb. Can I do it myself. Where can I get bulb.
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Samsung model hl-s4266w.. I can see the TV programs but it has gotten really dark. i think it's the bulb, but when i look on the back, the bulb is still on. Could it still be the bulb that needs to be...
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Samsung HL-S4266W 42" HDTV
I am having a problem with the red colour not being in alignment, it is almost like a shadow on the t.v. . How do I re-align this bulb?
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | Sony KP-53V90 53" Rear Projection...
Double image, blue adjusted, red won't adjust
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 19, 2009 | Philips 51PP9910 51" Rear Projection HDTV
3-d like picture
  • Screen looks 3D
Apr 14, 2009 | Hitachi 57F500 57" Rear Projection...
Double image
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Jan 27, 2009 | Sony KP-57HW40 57" Rear Projection...
43 philips problem with green
  • Screen looks 3D
Jan 24, 2009 | Philips 43PP9202 43" Rear Projection...
ALOT OF BLUE ON THE SCREEN!!
  • Screen looks 3D
Aug 20, 2008 | Philips 60PP9200D Television
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
