Question about HP PSC 2210 All-In-One InkJet Printer
The display shows "Press Enter to align cartridges." (I had installed two new ones.) No matter what I do, the messages continues--can't print, can't get it to stop.
    President:
  • 2,306 Answers
It has to complete the alignment procedure to continue. If any colors or black ink is missing it won't be able to complete the alignment. You can also press a combination of 2 keys to bypass alignment but the message will return later.
Posted on Jun 19, 2009
ImWireless
  • 113 Answers
SOURCE: press enter to align cartridge
Please try this http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=60259&dlc=en&lang=en You may also be able to bypass this messgage by following the instructions on this link. Further, please check if the cartridges you are replacing are the correct ones.
Posted on Mar 01, 2007
SOURCE: align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Posted on Sep 13, 2008
  • 8 Answers
SOURCE: Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Posted on Nov 02, 2008
  • 990 Answers
SOURCE: Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Posted on Dec 13, 2008
anujbhatt
  • 66 Answers
SOURCE: Printer does not respond to "Copy" command
Press and hold the Setup button, and then press Options (or Copy Options ).
It will bypass the alignment.
Posted on Apr 10, 2010
Testimonial: "Thank you, It worked!"
How do I reset my hp officejet 6110 all-in-one printer? It keeps asking me to align cartridges.
Press menu and then press the Right Arrow key until you get to maintenance screen then press enter.
Option 2 is you align print cartridges.
Automatic cartridge alignment
Perform the following steps to align the ink cartridges:
1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
1. Press Setup or Menu on the front panel (depending on the model).
2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
If the message keeps reappearing or other print quality problems occur, service the product.
Mar 30, 2011 | HP OfficeJet 6110 All-In-One InkJet...
New ink cartridge added message 'press enter to align cartridge' ends with Alignment cancelled' message and will not print . The message will not go away
Perform the reset of the printer:
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One
If your issue gets fixed, please come again to give us a
vote which will really motivate me to help people in
future.
May 10, 2010 | HP PSC 2175 All-In-One InkJet Printer
Display message won't stop: Press Enter to align cartridges.
I honestly don't know how I solved it; I did everything your forum suggests at least two times (restarting, disconnecting, re-installing, etc), but nothing would work. After I got up the next morning (four hours sleep!), I did it all again, and this time it worked. I did two things differently that may have worked. Somewhere in the owners manual, it says to wait for quite a long time (like over 5 minutes--I don't have the manual with me now). Also, it says to NOT turn the printer on until AFTER installing the software. Those two little items may have made the difference, but the main idea of reinstalling came from you. Thanks!
Jun 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Changed black cartridge. Machine works fine, but
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
Press and hold " setup" button then press " option "  will skiip alignment
Sep 22, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
117 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
