Question about Kenmore Freezers
Defrost Kenmore LR67369 - Kenmore Freezers
Excess water drips throughout freezer during defrost cycle
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Jun 01, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Is the kenmore under the counter freezer 5649235011 manual defrost?
Yes it is manual defrost...i searched the parts breakdown and see no defrost components
Sep 07, 2011 | Kenmore Freezers
Need manuel for a Kenmore frostless quick freezer model #253.9280410
I don't have a manual but these are fairly simple. On the back inside below is a defrost heater and terminator sorta like this:themobilian_747.jpg
The cold control maintains the temp and their is a timer that either puts it in run for 10 hours or defrost for 21 minutesthemobilian_748.jpgThe compressor relay goes out on these. The defrost heater or defrost heater termination themostat can cause defrost failure if bad.Not much to these babys.
Jan 07, 2011 | Kenmore Freezer 11.6 cu. ft. Upright...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Does the kenmore cold spot chest freeze model 253.8193610 have a defrost timer
Chest freezers don't normally self defrost. They just freeze. To defrost them, you must shut them off.
May 02, 2010 | Kenmore Freezers
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Kenmore 15.2 upright freezer coils freezing up
Check the bi-metal switch. when cold, it should have continuity also.
If both heater and bi-metal are good, change the defrost timer
I hope this helps.
Please leet me know if I can assist you further
Vic
May 31, 2009 | Freezers
Defrosting
Hi, Is the compressor running? How old is it? Is the compressor clicking off and on like it is trying to start but can't?
I want to try ans help, just need some answers.
Vic
May 16, 2009 | Kenmore Freezer 20.6 cu. ft. Manual...
Freezers Logo
186 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
