Question about HowiGripp Pan Grabber
What hand pressure is needed to operate the howigripp?
What is the grip strength needed to use the howigripp
I want Boots made only in the USA. Are there any brand of western boot made here in the good Ol USA?
Hello F J, Red Wing Shoes are made in America. They mostly make work boots but they also make western boots.
Nov 19, 2015 | Dingo DI19057 Western Motorcycle Boots...
Tip
Wrestling workouts
When training for wrestling, you should focus on three things: grip strength, pulling strength, and hip and leg strength. Grip strength is essential in all levels of wrestling because wrestlers use their hands in pretty much every part of the match. Exercises that improve grip strength include pull ups (can be done weighted as well if bodyweight pull ups are too easy), farmers' walk, reverse curls, and bar curls. Pulling strength is essential in wrestling as well because the wrestler uses his pulling strength in many ways during the fight (during takedown, when fighting for position, etc.). Exercises that improve pulling strength include back exercises like lat pulldown, pull-ups, and standing and seated rows. Other exercises include bicep curls and shrugs. Hip and leg strength is essential for explosiveness and increased flexibility. Exercises that improve hip and leg strength include squats and lunges.
on Aug 06, 2012 | Wrestling
What gear can I use to strengthen my forearm?
What I found to workgreat for me is the Valeo Ultra Hand Grip. You can buy it here, along withother great products: http://www.bodybuilding.com/store/wrist-forearm-strength.html
Jul 25, 2012 | Exercise & Fitness
Samsung camcorder SMX-F34BN. Need to replace hand grip. Have replacement part, but do not know how to remove old and replace. Help
Follow the steps to replace hand grip :
Remove two screws near battery
Remove the tiny screws on each side of the hand grip release.
Once screws are removed, gently prise of button. Do not attempt to remove the lever.
Remove the four screws holding the eyepiece in place.
Once the four screws are removed, pull out the eyepiece, notice the button that operates the cartridge access.
On the top of the camera, using a pointed tool and light hammer, gently tap in an anti-clockwise direction.
Now slowly lift from the front, taking care not to damage the power zoom buttons on the other side, and slide towards rear of camera to remove cover.
With the camera facing you, remove screws below the lens, then gently remove the side cover above the hand grip.
Use a blade to scrap away glue around the two screw heads, then remove screws. Then, using a pointed tool, insert into one of the small holes, and using a light hammer, gently tap to unscrew the hand grip screw.
Thats it hand grip is removed . Now replace the hand grip and follow the above steps in vice versa .
Hope this helps .
Mar 29, 2010 | Cameras
Tire pressure
You'll get a lot of opinions on what tire pressure to run but the correct tire pressure for you is not a matter of polling other rider's opinion. Here are the basics you'll need to decide for yourself. Start with the BIKE (not the tire *see below) manufacturer's recommendation in the owners manual or under-seat sticker. This is the number they consider to be the best balance between handling grip and tire wear. Further if you're running alloy wheels on poor pavement, consider adding 2 psi to the recommended tire pressure just to reduce the likelihood of pothole damage. Just as you would for a car, increase the pressure 2 psi or so for sustained high speed operation (or 2-up riding) to reduce rolling friction and casing flexing. Check your tire pressure regularly, as they say. In order to get optimum handling a tire has to get to its optimum temperature which is different for each brand of tire. Unless you own a tire pyrometer that will measure tire temperature directly, you’ll need to measure it indirectly by checking tire pressure since tire pressure increases with tire temperature. Tire temperature is important to know because too much flexing of the casing of an under-inflated tire for a given riding style and road will result in overheating resulting in less than optimum grip. Over-pressurizing a tire will reduce casing flexing and prevent the tire from getting up to the optimum operating temperature and performance again suffers. Sliding and spinning the tires also increase tire temperatures from friction heating. A technique for those wanting to get the most out of their tires on the street is to use the 10/20% rule. First check the tire pressure when the tire is cold. Then take a ride on your favorite twisty piece of road. Then, measure the tire pressure immediately after stopping. If the pressure has risen less than 10% on the front or 20% on the rear, the rider should remove air from the tire. So for example, starting at a front tire pressure of 32.5 psi should bring you up to 36 psi hot. Once you obtain this pressure increase for a given rider, bike, tire, road and road temperature combination, check the tire pressure again while cold and record it for future reference. Each manufacturer is different. Each tire model is different. A tire design that runs cooler needs to run a lower pressure (2-3 psi front) to get up to optimum temperature. The rear tire runs hotter than the front tire, road and track. So the rear tire cold-to-hot increase is greater. Dropping air pressure has the additional side effect of scrubbing more rubber area. When I used the tire pressures recommended by Ducati (32.5F/36R) for my 916 on my favorite road, I got exactly 10/20% on a set of Bridgestone BT-012SS. So I guess I'm an average rider and the BT-012SS runs at an average operating temperature compared to other brands. For the track you'll have to drop the cold tire pressures an additional 10/20%. Track operation will get tires hotter (increasing the cold-to-hot pressure range) so starting at say 32/30 psi now should bring you up to the same temperature (and pressure) that 35/39 psi gave you for the street. Don't even think about running these low track cold pressures on the street. Finally, dropping tire pressures on street tires for track use has its limitations, so street compound tires on the track often get too hot and go beyond sticky to greasy. That's why you have race tires. Race tire compounds are designed for severe operation at these higher temperatures for a limited number of thermal cycles. On the other hand, a race tire on the street usually won't get up to the appropriate temperature for good performance. At street speeds, the race compound often won't perform as well as a street tire. Finally, a tire that is inflated to a lower pressure than recommended will have a tire profile that will sag slightly in the middle. This sagging profile results in increased rolling friction and causes the tires to run hotter. This will reduce tire life but it will also increase tire traction or grip. Depending upon racing conditions and the overall setup of the bike the increased grip may be necessary to be competitive even at the cost of tire life. * Tire Manufacturer's Recommendations Japanese sportbikes seem to have an extra 4-6 psi specified for their tires, compared to the equivalent Ducati. Why? A tire manufacturer will recommend a pressure that is a balance between tire life and grip. When a bike manufacturer is developing a new model their test riders will determine what pressures in their opinion, best suit the new model. The recommended pressures are the best for general street (not track) riding, so you can increase grip somewhat by reducing pressures. But to answer the question about higher recommended tire pressures for Japanese in-line fours versus Ducati twins - in-line fours heat up their tires more than a twin so a higher starting pressure is needed to prevent overheating the tires, particularly the rear tire. Years ago, superbike racers discovered that it was easier to modulate the power to prevent wheelspin on the Ducati V-twins than it was to do the same on the Japanese inline-fours. This is because there is a longer interval (in terms of both time and crankshaft rotation) between cylinders firing, which gives the rear tire a break - time to recover traction and match its speed to that of the motorcycle. More recently, more sophisticated traction control systems have been tried to reduce tire temperatures, improve tire life and lap times,,,
Nov 10, 2008 | 2008 Buell XB12XT
Tire pressure
Nov 10, 2008 | 2001 Bimota SB6R
Tire pressure
Nov 10, 2008 | 2004 Bimota 666 L.E.
Tire pressure
Nov 10, 2008 | 2008 Benelli TnT 899
Tire pressure
Nov 10, 2008 | 2008 Benelli Bx 505
Tire pressure
Nov 10, 2008 | 1972 Aermacchi Sprint 350
HowiGripp Pan Grabber Logo
70 people viewed this question
Top HowiGripp Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a HowiGripp Hardware and Accessory Expert? Answer questions, earn points and help others
