Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a coleman powermate generator with a robin ex30d engin. its a 6250/5500 w . nowere can i find the H.P. of the engine.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
Normally that is a 5 HP motor
Posted on Jun 20, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Robin engines won't start
Look for kill switch. Make sure it is wired correctly and not broken or something like wires no connected. It cuts spark when activated so likely the problem since its in-line with exciter.
Jan 04, 2014 | Coleman Powermate Premium Plus 6250...
I have a Coleman Powermate PM0435001 5000W with a Subaru EX30D 10HP OHV/OHC gasoline engine. I want to change the oil and cant find a drain plug. Did I overlook it or does it not have a drain plug? If not...
You probably overlooked the drain plug, it is usually located on the mounting base of the engine. BUT, there have been some engines (old cheap ones) that the oil was drained by tipping the engine and draining out the oil fill. I am almost positive yours is not one of these.
Your manual is here, but that is only an "insert". It does look like the drain plug is located on the base of the engine. Find the spark plug, and the drain plug is almost directly underneath it at the very bottom of the engine.
More information is available from Subaru's website, including owners manual and especially a service and parts manuals. Your drain plug is item #13 on page 2 of the owners manual located here:
http://www.robinamerica.com/pmanuals.aspx?pid=80
Jun 06, 2010 | Coleman Powermate Powermate 5000W...
Is Husky 5000w a Chinese product?
Well tricky question ...Coleman factory is out of Wichita, Kansas that is there headquarters. but Subaru's head office is out of Nishishinjuku, Shinjuku-ku, Tokyo. so i think you have a mixed bag...good luck
Apr 17, 2010 | Coleman Powermate Subaru 5000W Portable...
How to remove coleman powermate 5000 generator from Tecumseh 8 HP motor for engine model number hm100.
4 bolts to the engine then altenator will just pull off may need a puller to get it moving
Feb 01, 2010 | Coleman Powermate Powermate 5000W...
Where do i get a coil at?
Well, if Briggs and Stratton engine, then try briggs and stratton.
If Robin / Subaru engine, try there.
Write down the model type and serial numbers, then pay a visit to local small engine repair shop and have them order for you.
Dec 21, 2009 | Coleman Powermate Powermate 5000W...
Where can i find oil dip stick for a generator coleman powermate subaru engine.
on the side of the engine there is a bolt like piece with two round like nodules on it, its plastic.
Oct 08, 2009 | Coleman Powermate Powermate 5000W...
Where can I get an subaru engine manual for 10 hp
Here your are. Subaru engines are made by Robin. I don't know if Robin owns Subaru or Subaru owns Robin. Any time you need a manual you can get it from the Robin America site.
http://www.robinamerica.com/media/manuals/128547541213915000.pdf
Feb 27, 2009 | Coleman Powermate Premium Plus 6250W...
ENGINE OVER SPEEDS WHILE RUNNING
This is almost surely a problem with the governor, check it like this.
Have someone with a finger on the kill switch.
Watch the governor arm while starting the engine, if it does not move almost immediately after starting the engine it is broken.
This is not a simple repair as it involves taking the crankcase apart, you'll have to contact robin/subaru to get a parts list in order to get the right governor spool and weights.
For an experienced technician this is about a 2 hour repair task.
Hope this helped,
Carl
Dec 03, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
295 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
