Question about Brady Promo Bbp33-promo3 - Promo Bbp33-promo3 Label Printer
MY BBP33 QUIT WORKING, HOW DO I FIX IT?
IT LOST ITS CONNECTION TO THE COMPUTER AND WILL NOT PRINT ANYMORE
I seem to have lost my files on my Iomega hard drive?? It will no connect up to my computer anymore.
not at all external hard drives fail quite often . there are places that might be able to recover your info but it will not be cheap
Feb 24, 2015 | Iomega Computers & Internet
Can't print. Lexmark has an x by offline
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X6150 All-In-One InkJet Printer
My printer will not communicate to my printer, and it did recntly. just stopped working a month ago.
Do a normal power off (leave the printer powered on) on the computer and after 5 seconds re-power the computer on and you should hear the printer do a reset and become ready. I've had the same problem, it's in the printer.
Jul 22, 2011 | Lexmark X5650 All-in-One InkJet Printer
My printer does not print from the computer nor does it print copies.
Try this utility: Print Flush 1.3
Fix your printer with this small utility!
Has your printer quit working? Did you try to cancel a job and it broke the printer completely? I always do that. And the method to fix it usually involves rebooting, restarting the print spooler, trashing junk print files, and sometimes even more. Not anymore.
Print Flush has a simple function: clean the print spool. If your printer's driver is incorrectly installed, Print Flush cannot help you. If you have used your printer before and it worked fine then, but it doesn't now, Print Flush can probably help you.
It also works with Vista.
http://www.bradkovach.com/printflush/
  1. Save somewhere where you can find it.
  2. If you downloaded the zipped version... Unzip the file to the desktop or something
  3. Double-click the file
  4. Try printing again!
Jul 20, 2011 | Dell 946 All-In-One InkJet Printer
I had to disconect the printer to move it I've conected it all back up it has power but the computer keeps telling me it's offline. Help please, Ive run my trouble shooter and it is telling me that...
Use Print Flush 1.3 to fix it:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Jul 18, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Single print
check in page setup plz
Jun 25, 2010 | D-Link DP-G321 Print Server
Cant scan with my Cannon PIXMA M470 anymore
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-9
Apr 21, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP printer will not print over wireless network using Belkin hub
Try turning everything off, wait a couple of seconds and then turn it back on.  Also try disabling McAffee to test.  When you go to printers and faxes on the PC, what is the status of your printer?
Apr 16, 2009 | Belkin (F5U237) 7-Port USB Hub
Lexmark Printer - Lost connection to the PC?
I had to reinstall printer and download a new driver from Microsoft for Vista (by Jan 08 there were MANY revisions). It also helped to unplug printer connections, turn off computer and pug printer back in before rebooting. But you'll haveto keep doing this until you reinstall.
Feb 17, 2008 | Lexmark X1270 All-In-One InkJet Printer
Error 5100
Maybe you haven't put your ink carterages in properly, I had the same problem and fixing their position solved it
Oct 08, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Brady Promo Bbp33-promo3 - Promo Bbp33-promo3 Label Printer Logo
145 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
