Question about Canon PIXMA iP3000 InkJet Photo Printer
Will not print black
I put a new black ink tank in, it printed some documents fine for a while then the next day it would not print black text.i have done the deep head cleaning process a few times, i have uninstalled the driver and reinstalled it a few times still no change when print a test page all colors are fine and the little squares on the left side with the 6C inbetween them are fine but the black grid that is supposed to be above the color lines is not there.i have checked the fonts the cartrige, the print head alinment,page setup printer setup, still no change, could it be a dodgy cartrige or damaged print head?
  • youngone Nov 04, 2007
    thanks wbmassel your right i have a conpatible ink cartridge so i will try a genuine one.the weird thing is i am able to print on to dvds,and cds in black but not text to paper..it has been a great printer up till now but it may not be the printer
  • 26 Answers
First of all the most important auestion is have you used compatible ink cartridges or genuine ones, because the print head clogs up with compatible ones, i really doubt that the cartridge you installed is damaged because i haven't come across this and i am a canon technician, i know this model well
Posted on Nov 03, 2007
My mp610 has just got new inks in it. I did the calibration and everything was fine but when I printed off a PDF document it only printed the coloured text and not the black. could it be possible that the...
yes because u installed both cartridges. if you only installed the color it will still print black by mixing the three colors (known as composite black) try to change the black first or remove it and use the composite black to print black text.
Feb 13, 2010 | Canon PIXMA MP610 InkJet Printer
Why does canon 860 pixma printer have 2 black ink tanks? only one seems to be used,
The big black tank is pigment based ink used mainly for printing text documents and copies and the smaller black is dye based ink used along with the color inks during photo printing.
Dec 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Not understanding why there's two black ink cartridges
One tank is reserved for colour printing and the other one is for grayscale printing ( Black and white). Watch out as when you run out of ink and you keep trying to print a document with empty tank cartridge it will cause your print head to go bad. The cost of a new canon print head is the same as the cost of a new printer. Canon over priced the print head.
Nov 30, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Word 2003 not printing text, but prints everything when a clip art is added
I solved it! Aint no stopping me now!!!
This may not be a permanent solution, but it is one that will remedy the problem if you are caught in a bind!
Change the color of your document to the next color lighter than black but dark enough to print as black. Other colors do print.
Perhaps it is a problem with the black ink and/or cartridge.
My 6 page document printing normal with the exception that I changed it from the default black setting to the next lighter black color.
Now who will pay me for this tip? No charge, just kidding!
Sep 24, 2008 | Microsoft Office 2003 Pro (269-07387) for...
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
DigiChick
Jun 09, 2008 | HP Color LaserJet 2600n Printer
Why is there 2 black ink cartridges in my Canon MP600 printer
On some printers, probably including yours, the black ink will be taken from the reserves in your colour cartridge unless you specifically tell it to do a black and white print on each document, regardless of whether it's printing black exclusively. I wouldn't worry, the black ink in it's own cartridge can also be used for colour photos etc with no detrimental effects.
Mar 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Ip4200 stopped printing...help!
dear oceantracks maybe one of the black cartridge chip think that ink is running low or not ink is left in the cartrridge.
Nov 21, 2006 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
228 people viewed this question
old marine
old marine
