Question about Masterbuilt 20070106 Electric Smoker
Masterbuilt 20072612 ERR1 error code
Doing initial burn in and unit shows ERR1 error code and shuts down. Unplug for 10 seconds as manual specifies to reset control board but does not resolve the problem.
    New Friend:
Posted on Oct 19, 2016
2 Suggested Answers
  • 3740 Answers
SOURCE: Masterbuilt smoker model 20070910 with
Hi and welcome to FixYa, I am Kelly
It is telling you that the temp is below 40 degrees F. All you need to do is warm up the temp probe to 40F and it should work just fine. Use a hand held hair dryer or a warmed up shop vac on b.l.o.w to warm it up.
Happy New Year,
Posted on Jan 01, 2011
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
I have replaced waste toner unit with new one on a WC 5050 and still shows the error message as full so unable to print
Reset to Default settings, if that does not work, shut down printer, unplug power from printer, shut down computer unplug power from computer, wait 20 seconds, plug power in to computer plug power in to printer, wait 5 seconds, boot computer, turn on printer.
NOTE: This should solve most problems with printers.
If still not working you have a faulty Toner unit.
Sep 21, 2013 | OKI C9600hdn Laser Printer
My T.V. Will power on for a couple seconds then immediately turn off! Please help!
Unplug the unit from the outlet for at least 1 hour and check if the symptoms persists. If yes, check if the unit can give an error code by following the steps below.
- Power on the unit and wait until the initialization takes place.
- Press the front panel "Input" and "Menu" buttons at the same time and hold it for 5 seconds, it will activate the error code mode. LED flashes a two digit error code. Example, if the error code is "22" the LED will flashes two times pause and then flashes two times and will repeat the error code for 5 times.
"12" means no error has occured.
Please let me know what will be the result to assist you further.
Mar 07, 2012 | Mitsubishi WS-55313 55" Rear Projection...
E1 shows and i unplug the unit and it will run for about 2mins and shut down with e1 showing
The E1 error code indicates that the air intake filter is dirty or clogged and needs to be removed and cleaned. Turn the unit OFF & unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so, can damage the unit.
Hope this helped you & thanks for choosing FixYa.
Sep 20, 2011 | Haier Heating & Cooling
Code 3452 and my touch screen is not working
These could be related problems, however I doubt that they are. The error code 3452 refers to thermistor not reaching temp within specified 30 second time frame. There is a sensor there that monitors this. Touch screen may not work due to error code. However, I'm a little suspect that it may be a different problem. But first, let's solve the initial issue and then move onto the screen.
Try clearing the error code first, and then if it appears again, you'll need to look at replacing either the sensor or thermistor. If you are not a certified technician, but attempting to resolve yourself, I would suggest sending the fuser back to whomever you purchased it from and telling them to supply you with another one. During rebuild they probably did not properly gauge the sensor from the fusing roller. therefore it is not able to properly monitor temperature. (very common problem)....
Here is the instructions for clearing the error code:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while holding down the Utility/Counter key more than 10 seconds after. A screen will appear saying "TROUBLE RESET"
4. Check to make sure that "OK" is displayed below which confirms it has been reset.
If "OK" is not there , it will show a different code....
IF it says "OK", you should be good to go. Error code should now be cleared.
5. Just Turn off the Main Power Switch wait at least 10 seconds....and turn it on. Make sure that the machine properly starts.
** If it re-displays the code again within a short period of time, replace the fuser unit. Or get a certified technician to replace the or adjust the sensor or Thermistor unit. However, since you just purchased this I will assume that it is either a defective unit from manufacturer, or the company who rebuilt it did not properly ensure it was working. Return it and demand a replacement in EITHER case!! J
Hope this helps
Sep 02, 2011 | Konica Minolta bizhub C450P Laser Printer
I am getting a EEAF fault code and the smoker will not heat. What is wrong?
To RESET control panel:
If control panel shows an error message, turn electric smoker off, unplug unit from outlet, wait
ten seconds, plug unit back into outlet, then turn electric smoker on. This will reset control panel.
MODELS 20070106, 20070206
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
Error code: 0xc18a0001
This error code indicates that you have an 'Ink system failure'. The problem is caused by air the ink feed tubes. If you either use all of the ink down to 0% or you use poorly refilled ink cartridges it can cause the printer to **** air into the feed tubes instead of ink. We have a step by step guide to purge the feed tubes of air on our site at: There are 2 different versions of the procedure find the one for your type printer and follow the guide and within about 10 minutes you will be printing again.
I hope this helps, if so please rate our solution.
Corporate Computer
Apr 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
Copier is a 214 and shows U4 code
turn on power while holding down "0", press "stop/clear" and wait 30 seconds for optics to finish initializing, then enter "401" then "print", shut off machine, wait 10 seconds and turn back on. code should now be cleared.
Sep 06, 2009 | Xerox 212 Laser Printer
After getting error 79 won't print
A solution:
  • Unplug
  • Hold down "*" & "enter/ menu buttons"
  • While holding down both buttons, turn power on
  • Wait until something like "initialize" shows up on the display
  • Let go of buttons
  • Wait until display reads "ready"
  • Unplug for 10 seconds, then plug back in
  • Hope it works for you
Apr 24, 2009 | HP LaserJet 3330 All-In-One Printer
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Masterbuilt 20070106 Electric Smoker Logo
1,178 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
