Question about Icom BP-195 BP-196 IC-A4E IC-F3 IC-F4 IC-T2A Replacement battery
How to get rid of busy
The radio constantly says busy on display, even when sch is off
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Remove Battery and insert again, reprogram it, adjust squelch level.
Posted on Jul 11, 2016
I have purchased a second hand set of Motorola xtnid radios, the old company's name is still displayed in the screen when I first switch it on, how do I remove it ?
Depending on the radio, mots Motorola business radios are programmed with a computer and a cable that attaches the radio to the computer, or a programming RIB. This all depends on the age and model of the radio, but since you said that a companies name appears in the display, I am pretty sure it is a business band radio that has to be professionally programmed. I say professionally because even if you have everything you needed to program the radio, I sincerely doubt that you will be able to do it. Motorola software is called CPS, but then again, it depends on the age of the radio, newer Mototurbo XPR radios use a much newer software, and they interface to the computer in a different way, that is without the use of a programming RIB. A RIB is a box that goes between the radio and the computer, newer radios only need a simple USB cable that is made to mate the radio to a uSB port.
Dec 09, 2015 | Radio Communications
What does TOT mean on display?
TOT Penalty means: If the radio transmits more than a set time, it will beep an T-O-T error tone and the radio will only receive a signal for the penalty time. (TX inhibited for this time).
Under the above mode, press Up/Down buttons to select On or Off and then press Mode button or PTT button to set Busy Channel Lock Out. The radio will then save selection and exit to receiving stand-by
mode.
To DISABLE... navigate the menu to "PENALTY" in the display... press mode button... then use UP or DOWN buttons to select mode... to disable select "OF" (which means off).
Good Luck.
Apr 26, 2014 | Midland M222P (22 Channels) 2-Way Radio
Uniden uh65sx radio has constant busy sign on screen
The squelch control is too far open and results in it thinking the channel is busy.
Jun 13, 2013 | Radio Communications
The radio can not playing even when you try to enter the code and is constantly displaying radio code error
radios not the one that matches the car . something was changed , possibly cars computor or some type of mod
Dec 28, 2010 | Car Audio & Video
Iocked out of radio
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
If it says LOCK13 then too many wrong codes have been entered
Jun 09, 2010 | Mac-Audio Dynamic 2.13 Car Component...
What is busy indication on uniden uho65sx-2. The radio appears not to recieve, cant get rid of busy indication.
the uniden was returned to Aucklands "wonderful" service team and it was found the ceramic coil inside had been damaged, after i dropped it I would say!
Nov 17, 2009 | Uniden Radio Communications
Can't get rid of message symbol
Hi, did you checked your MMS or email? it looks like unread MMS.
Rate me if it helped. Thanks.
Apr 13, 2009 | Sony Ericsson T280i Mobile Phone Silver on...
Need Hard Reset Code for for Samsung SCH-u340 (US.Celluar)
half impriset- *2767*2878#
full impriset- *2767*3855#
ok
thank u.
Jan 10, 2009 | Samsung SCH-u340 Cellular Phone
Uh049sx." BUSY" light on all the time. wont recieve
Contact a service center in your own country.
turn the squelch button down.
Oct 19, 2008 | Radio Communications
Car Radio, Casette Player and CD Player not working
Hello Lei,
It sounds like the antenna has came loose from the back of the radio and the wiring harness is loose.
Make sure you have a good ground going to the radio, or this will cause a short and make the radio do strange things, the fact you sometimes get a signal tells me the radio is in working condition.
Sep 22, 2008 | 1997 Ford Expedition
Icom BP-195 BP-196 IC-A4E IC-F3 IC-F4 IC-T2A Replacement battery Logo
83 people viewed this question
Top Icom Radio Communications Experts
Steve
johncassells
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
