Question about Dishwashers
Auto timer does not wor - Dishwashers
What does diagnostic code p1633 mean?
It depends on the vehicle. You can usually goolge yoir year make and model with the wors trouble codes and get a list of specific information.
Jun 23, 2014 | Ford Vehicle Parts & Accessories
Tali light out break light works
Check your fuses and bulbs, just because the brake lights work does not mean your tail lights do, $15 you can replace them all at auto zone
Apr 18, 2014 | 2001 Dodge Ram 2500 Truck
Car doors are froze shut
ger a large bottle de-ice spray both doors locks
Jan 07, 2014 | 1998 Chevrolet Monte Carlo
Do I set the GE timer # 15089 to Auto on or Auto off for it to be activated. I had it on Auto on however the light stayed on all the time.
I don't have repair for defective timer.
Open following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15089
Timer should be set to Auto ON for timer programs to run.
Auto OFF is temporary override, and timer resumes schedule at next set point.
ON is always ON
OFF is always OFF
If timer is not operating as expected:
Test outlet for correct polarity and electrical problems using cheap circuit analyzer from hardware store.
Timer programs can have conflicts. Make schedule before setting timer so there are no overlaps that cause timer not to function as expected.
Current time has not been set. Set current time including current day.
Set button has been accidentally pushed, and a number or CTD appear in display.
Timer needs to be reset to clear conflicting programming or error. Push reset button with paperclip and try programming again.
Timer is not able to handle intended load. All timers work for incandescent bulb. Connect timer to incandescent lamp and see if problem continues.
Timer is defective. Buy another timer from Home Depot and return defect in new package.
Aug 17, 2011 | Jasco Ge 7 Day Digital Timer 1 Outlet...
I have the timer programmed but what mode should it be in Off, Auto or Random? I had it in Auto but the timer did not start at 10 am as programmed! Help!
HB88RC is discontinued timer, replaced by 2-outlet HB800RCL or 1-outlet HB800RCH.
Timer functions should work in AUTO.
Try resetting timer by removing AA battery, reinstall fresh battery, and then reprogram timer.
When programming is finished, press clock button and timer should be in AUTO mode and current time displayed.
If you want to change mode, then press mode button. When exiting mode, press clock button and timer should be back in AUTO mode.
If functionality does not restore, then timer has gone bad.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://waterheatertimer.org/pdf/hb88rc.pdf
Jul 05, 2011 | Intermatic HB88RC Outdoor Timer
Resetting the timer for Auto
http://waterheatertimer.org/Woods-timers-and-manuals.html#Hamilton
I do not know how to 'reset timer for auto'
The reset button is small round button with R
Manual says: "ON/AUTO/OFF" override. Press "ON/AUTO/OFF" or the
button with the "HAND" symbol to force the timer into permanent
"ON" "AUTO" program or permanent "OFF" mode.'
When within the programmed window (preset time period),
cycle through "ON/AUTO/OFF" button to "ON" mode
(indicated by lighted red LED above display), and then
"AUTO"
I have not tested this timer, but the manual sounds vague and confusing, leading me to believe you have to tinker around with the buttons and settings to make sense.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 26, 2011 | Vista Pro Digital 7-day Electronic Timer...
I need to know more about "Countdown - Auto -
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
59377 manual
http://waterheatertimer.org/pdf/Woods-59377.pdf
Auto: timer must be set in AUTO for programming to work
The word AUTO is printed on timer face.
Small black triangle will display above the word AUTO when timer is in AUTO
Countdown is feature that lets you set timer ON for set amount of time, and when time expires, timer turns OFF.
Manual button.
I have not tested this specific timer.
Simply plug lamp into timer, and then push manual button to explore feature.
Watch what symbols display, and watch what lamp does.
Add a comment for more free help.
Mar 08, 2011 | Woods Industries 59377 Indoor Digital...
I have sharp lc-c3742u,it turns on just for a sec. and then picture is gone green light stays on but no pic help
Issues with the auto screen control. Check the set up and see if all the adjustments are out of wack.Try bringing them ito normal picture manually. If this does not wor it is tech time
Mar 25, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
ICe build-up on coils and frezer does not freeze after a few weeks from thawing.
Check the defrost timer which may be behind the kick-plate, inside the control panel or an Adaptive Defrost Control (motherboard) on the back.
Apr 22, 2009 | Refrigerators
Dishwashers Logo
13 people viewed this question
Top Dishwashers Experts
