I have a LG Fuzzylogic WFT8018TP An error code PE on pad What does that mean It just gives one spin then the alarm goes off
2 Suggested Answers
SOURCE: error code PE on top loader(LG)
Check the pressure switch -the system that determines correct waterlevel in the drum. If its giving an incorrect indication to the programtimer machine will either overfill, refuse to fill or refuse to spin.Its an air operated diaphragm switch triggered by rising air pressureinduced by the entry of water into an airtight vessel attached to thebase of the drum. It tells the program timer that the water has reachedthe correct level, allowing it to proceed to the water heating stage inthe cycle. Power off, drag machine out onto the floor, remove backcover and top cover. The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. It generallysits just under the top cover. Disconnect the thin rubber pipe from theswitch and blow down through it to clear any blockage. Switch itselfmay be faulty but its more likely the pressure pipe or the vesselattached to the other end of the pipe is blocked. Some machines havethe pressure vessel integrated as part of the filter unit, with apressure chamber moulded into the top of the filter body. Remove thepressure vessel, put a small nut or screw in it, fill it with water andshake vigorously till any crud or residue is removed. Refit all parts,check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at thefoot of the machine.Some are obvious like little square hatches andsome are hidden behind the trim panel at the foot of the machine. Oncepanel is removed the filter should be visible. Its generally a circularplastic fitting which unscrews in an anticlockwise direction. Somehotpoint, indesit and ariston filters are located in the big black sumphose (the one that leaves the bottom of the outer drum and connects tothe pump). Power off, drag machine out onto the floor, remove backcover or tip machine up at an angle. Locate sump hose, remove thetensioner clip by squeezing the tabs together with a large pair ofpliers or vise grips, remove the hose, take out filter and clean. Beprepared for spillage of water. May help if the machine is tiltedbackwards at an angle.
Repair and service your own washing machine. Go to www.2ndwave.co.uk/manual.html
Posted on Jan 13, 2009
Tip
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG washing machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
on Mar 15, 2010 | Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
Error PE on model wm2016cw, is this an easy fix?
Error Code PE mean Pressure sensor Error code
Check wiring connection to the pressure sensor; to solve it replace pressure sensor. The sensor repair is simple and straight forward.
Additonal details could find in this link: LG_Knowledge_Base
Hope this helps.
Aug 02, 2011 | LG Washing Machines
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
How to reset eprom for PE error
Hi, PE error code means there is an pressure sensor error in your machine .You need to check pressure it will be giving incorrect indication . Pressure switch is faulty you need to change it . Procedure for changing is : 1.Power off the machine remove backcover and top cover. 2.The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. 3.It generallysits just under the top cover.
Apr 08, 2010 | LG WFT1071TP Top Load Washer
Error codes
Here are the common error codes for the LG machines.
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
UE
IE
LE
PF
FE
PE
CE
TE
SE
HE
DHE
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
