Question about Toto Aquia II Dual Flush Toilet
How to fix
Water flow
Spa indicator says Water SW Open...what does that mean and how do I fix?
This means that the pressure switch is not closing. Generally, this is a lack of water flow issue. The main cause is a dirty filter. Clean cartridges, backwash sand, backwash and recharge DE, whatever is needed to clean the filter, this should fix the problem. If not check other sources of restricted flow: filter baskets, pump baskets, shut-off valves. If everything is clear and there is good flow returning to the pool it could be a bad pressure switch. Replace with the correct switch for your heater.
Sep 13, 2014 | Rheem Pool & Spa
Gurgling sound
Refrigerant migration nothing can be done.
Apr 28, 2014 | Scotsman Kitchen Appliances - Others
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
I get an F H code. I bought a new inlet value which fixed the problem for about two weeks. I then installed the old one wich lasted another 2 weeks. How can I find and fix the correct problem. Maytag ...
As i suppose you know by replacing the water inlet valve that the F-H error code means now water was detected entering the washer. having replaced the water valve,one thing you should check,espically if using"aqua flow flood stop" braided steel inlet hoses from the house water supply,is if water is flowing through the inlet hoses into the washer, if your using that type of hose from the faucet they have a problem in them and the internal flood stop device inside the hose fails and even though the water faucets are on no water is getting into the washing machine. Also or even if using those type hoses disconnect them from washer and check for water flow through them when not connected to washer. If water flow is good into washer replace this part called the flow meter part # W10110225 it measures and tells the control that water is coming into the washer. It the flow meter can of course be purchased where you got the water inlet valve.
Good luck,
Gene
Aug 19, 2011 | Maytag EPIC MFW9700S Front Load Washer
I changed my filter, PUR 4396841 and now it is vibrating when I stop dispensing water. Any suggestions? Do I have it installed correctly?
The vibration is a tiny bit of "water hammer." Previous to your filter change, the water flow was restricted, and therefore incapable of causing water hammer. Now that you've changed the filter, the flow is large enough to cause a little water hammer when you shut off the flow.
How to fix: shut off the flow SLOWLY. Water hammer is caused when the flow of water is shut down quickly. This is just as true with large flows (as in fire engine pump panels), as it is in itsy bitsy
filtered water lines & filter housings.
May 13, 2011 | Whirlpool 4396841 Whirlpool Refrigerator...
How do I increase the water flow on a Jandy LXi pool heater?
You can not increase the water flow through a heater by adjusting the heater. You either need to get a larger pump motor, fix a pump issue, or....
If the heater was installed correctly with a bypass, closing the bypass will force more water through the heater. If a bypass was not installed, a larger motor is needed to increase flow (unless you used to get enough flow and now you dont. I this case, fix the pump or backwash the filter)
Feb 15, 2011 | Jandy LXI 300 PROPANE POOL HEATER -
My kitchen facet will not activate the hot water buner now and it takes two hot water facets in the bathroom to activate hot water. Is there a maintenance pronlem I need to do? Where are instructions how...
There is a minimum water flow required to operate your Bosch tank-less water heater. It is around .75 gallons a minute. There are three things you can do to help the flow.
1.Turning the temperature down will help increase the flow.
2. Installing higher flow aerators on your faucets.
3. Clean the Bosch tank less water heater.
You are not alone in having this issue. The most common problems are low flow faucet aerators and low flow shower heads.
Aug 31, 2010 | Bosch Water Heaters
Cold water flow is extremely slow. have checked
REMOVE THE COLD WATER HOSE FROM THE WASHER, AN LOOK INSIDE THE VALVE, AN CHECK THE SCREEN, FOR BLOCKAGE, SPECIALLY IF YOU HAVE HARD WATER IN YOUR AREA.,
I HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | GE Profile WPRE6100G Top Load Washer
No water flow to the humififier
I've been working on the Aprilaire 110 unit today, after encountering the same problem. Here's how I fixed it: First, with the humidistat turned to 0%, I turned off the water supply saddle valve all the way (all the way to the right)--and then turned it back on all the way (all the way left). Still no water flow. Second, I slightly loosened the inline valve nut on the discharge side of the solenoid on the side of the 110 unit. Water began flowing, so I tightened it back up; and now the water flows freely. Conclusion: You may have some mineral deposit buildup in your lines, as I apparently did.
Nov 25, 2008 | Aprilaire 600 Humidifier
Low Cold Water Flow into Machine
the water inlet valve has to be replaced,its the part where you seen the screen ,where the hose hooks up to,theres a cylinoid that opens and closes and lets the water come in,your cylinoid is no good,but you change it as one unit,and its called water inlet valve,easy fix you can do your self,if this helps please vote me a fix ya
Jul 15, 2008 | Washing Machines
Toto Aquia II Dual Flush Toilet Logo
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
