Question about LG F-185 CD Shelf System
NEED EQUIVALENT MOSFATE FGA15N120 - LG F-185 CD Shelf System
What is equivalent to rotunda timing analyzer 05900014
You need to contact the local Ford dealer.
Feb 29, 2016 | 1995 Ford Taurus
What is equivalent to 6/8?
There are an infinite number of fractions equivalent to 6/8. Reduced to lowest terms, it's 3/4. Some others include 9/12, 12/16, 30/40, 60/80, 75/100, 300/400, 600/800, and 6000/8000. As a percentage, it's equal to 75%.
Feb 04, 2014 | Office Equipment & Supplies
What's a number equivalent to 100 using only the number nine
99.9999 repeating is technically equivalent to 100, depending on what level math you're in.
For example, 100 / 3 = 33.3333...
but clearly 33.333 * 3 = 99.9999...
So multiplying both sides of my first equation by 3, we get 100 = 99.9999
If you are not looking for "a number equivalent to 100" but "an equation or set of numbers equivalent to 100", then there are many ways. For example:
99 + 9/9 = 99 + 1
And 99 + 1 = 100
Jan 16, 2014 | RXE160 Equivalent NTE16013-ECG POLYMERIC...
I need to buy some power steering fluid for my 2002 Cadillac diville where and what kind do i buy
gmlogoflat.gif Service Information bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2002 Cadillac DeVille ' DeVille VIN K Service Manual ' General Information ' Maintenance and Lubrication ' Specifications ' Document ID: 792664 Fluid and Lubricant Recommendations Application
Fluid/Lubricant
Automatic Transaxle
DEXRON®-III Automatic Transmission Fluid
Chassis Lubricant
Chassis lubricant GM P/N 12377985 or equivalent lubricant meeting requirements of NLGI # 2, Category LB or GC-LB
Engine Coolant
50/50 mixture of clean, drinkable water and GM Goodwrench® DEX-COOL® or Havoline® DEX-COOL® Coolant
Engine Oil
Engine oil with the American Petroleum Institute Certified for Gasoline Engines "Starburst" symbol of the proper viscosity. To determine the preferred oil viscosity for the engine of this vehicle, refer to Explanation of Scheduled Services
Hinges, Hood and Door
Multi-Purpose Lubricant, Superlube® GM P/N 12346241 or (Canadian P/N 10953474) or equivalent
Hood Latch Assembly, Secondary Latch, Pivots, Spring Anchor and Release Pawl
Lubriplate®Lubricant Aerosol GM P/N 12346293 or (Canadian P/N 992723) or equivalent lubricant meeting requirements of NLGI # 2, Category LB or GC-LB
Hydraulic Brake System
Delco Supreme 11®Brake Fluid GM P/N 12377967 or (Canadian P/N 992667) or equivalent DOT-3 Brake Fluid
Key Lock Cylinders
Parking Brake Cable Guides
Chassis Lubricant GM P/N 12377985 or equivalent lubricant meeting requirements of NLGI # 2, Category LB or GC-LB
Power Steering System
GM Power Steering Fluid GM P/N 1052884 or (Canadian P/N 993294) or 1050017 or (Canadian P/N 992646) or equivalent
Weatherstrip Conditioning
Dielectric Silicone Grease GM P/N 12345579 or (Canadian P/N 1974984) or equivalent
Windshield Washer Solvent
GM Optikleen® Washer Solvent GM P/N 1051515 or (Canadian P/N 993033) or equivalent
i would just stop by your local dealer for the correct fluid. part number is listed.
Jul 29, 2011 | 2002 Cadillac Deville
Focal length equivalents
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}I believe it is equivalent to a 35 to 210mm lens on a 35mmcamera. If you are considering a Nikon such as the D60, D80, D90, etc.,the standard lens sold with the camera is 18-135mm. This is not the sameas an 18-135mm on a 35mm film camera. The equivalent 35mm film cameralens would be 27-202mm (you multiply by 1.5), about the same as what youhave now. If I were planning to do wildlife photography, I would buy a usedNikkor ED 70-300mm AF lens on E-bay. You should be able to get one for$200 or less (the new price is $550+). This lens is designed for a 35mmfilm camera and is the equivalent of a 105-450mm when used on a Nikon digital cameras. Additionally, it is compadable with the automatic features of the Nikon digital camera bodies. This would give you an excellent portrait lens at 105mm and extra long reachfor wildlife. The fast shutter speed and stabilization circuit on thedigital camera should make it usable in daylight without a tripod. I havethis lens on a Nikon film camera and it is a superior lens. At a 1/1000second or faster shutter speed, I get sharp hand held photos.
Nov 17, 2008 | Fuji Cameras
Need equivalent IC
i made programmer for 89c51. in this use ic ds275. i want know what is the equivalent ic of ds275.
Aug 10, 2008 | LG F-185 CD Shelf System
LG F-185 CD Shelf System Logo
113 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
PNiss
Mike Duncan
Mike Duncan
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
