Question about Bosch Drills
How to disassemble hammer mechanism - Bosch Drills
  • Bosch Master
  • 1,793 Answers
With the right tools depending on the brand and the kind of model.
There are much different kind of mechanism for hammering
Posted on May 09, 2016
How to adjust altitude drive on ultima 2000 telescope
use a claw hammer it will work just fine.. 2 shots should do it.
Jul 30, 2014 | Celestron Ultima 2000 -- 8 Telescope
Air opertes but locks up under load
Sounds like you might have a problem with the hammer (clutch) mechanism, these types of impacts are direct drive there a re no gears, so the hammer (clutch) mechanism must have the ability to splip after impacting to allow the air motor to turn. Disassemble and look for broken hammer pins, hammer dogs.
If you need a parts list you can go to CP.com, powertoolrepairohio.com or ereplacementparts.com
Feb 01, 2014 | Chicago Pneumatic 1/2" Air Impact Wrench
No power and just blows air
The problem stated could be in one of two places.
1st the hammer mechanism, symptom when trying to loosen or tighten a nut the tool locks up. Disassemble and and check components for wear or broken parts..
2nd under a no load condition, depressing the trigger and only air blows through the exhaust could be a combination of hammer and motor. Also must inspect the anvil bushing (item #19) located in the hammer case, they have a tendency to slide out of place and binding the mechanism as a whole, then check air motor for scarred a
endplate (item # 12) cylinder (item# 9, damaged vanes (item# 11)
Follow this link to the parts list. http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
Oct 23, 2013 | Ingersoll Rand 1/2" Air Impact Wrench Gun
How do I disassemble the impact mechanism?
wouldnt be surprized if its pressed together as if theres plenty of oil in there,they dont normally need stripping right down
Mar 04, 2012 | Chicago Pneumatic 1/2" Electric Impact...
Motor operates but drill has no power forward, only reverse.
you have a problem with the switch or the reversing lever. If you go to take it apart use caution that you do not disassemble the gear mechanism, you can find a breakdown and buy parts from them direct or they also have a locator at makitausa.com. I would look at the breakdown before trying to disassemble.
Aug 01, 2011 | Makita 8443DWDE Factory Reconditioned 18V...
Hi, Recently purchased a factory rebuilt 11255vsr and have put it to hard use. I'm noticing oil on the bit shanks, high heat @ front end, louder and louder noise. Nothing critical yet, but I hear it...
Here goes, the only real problem with disassembly is removing the shift selector, but first remove the bit lock mechanism, the dust shield pulls off and then you will find a retainer under that remove these and put them in toe order removed or take some pics to help later in reassembly. Removing the selector what you have to do is turn it to the hammer position and then depress the plunger all the way and turn it past the hammer cog, this will release the tabs that lock it in. As far as grease they make a special lube for the gears inside this tool. The wear items would be the armature/gear. To check for this before disassembly run the tool NO LOAD in forward and listen, then reverse the rotation and do the same, if is quieter that is where I would start to look. The screws holding the gearcase on are T20 torx. I would suggest going to "ereplacementparts.com" and downloading a schematic so you know what you are getting into.
Jun 24, 2011 | Bosch 11255VSR Factory Reconditioned 1"...
My cp772h is running low on power. I am unable to loosen bolts that I tightened on lower setting
The biggest problem I have seen with these is the hammer mechanism.Remove the front of the tool and disassemble hammers.Clean them good with solvent and using a paint brush re coat then with a special hammer grease that can be purchased at a local tool repair and supply store.Also check fwd and reverse seals while you have it apart.Check motor veins for wear.Check inlet screen and exhaust for debris.
Oct 19, 2010 | Chicago Pneumatic CP772H - 6 3/4" Heavy...
Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
DeWalt 567 rotary hammer won't hammer
If still under warrenty local Dewalt store will repair. Total rebuild $99.00 on most tools.
Sep 08, 2009 | Drills
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Drills Logo
153 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
