Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Black & Decker DCM18S Brew 'n Go LEAKING - Black & Decker SpaceMaker ODC325 Coffee Maker
5 Suggested Answers
SOURCE: Need owners manual for a Black & Decker DLX900 12-Cup Coffee Make
I need to program my coffee maker to come on in the morning, I have lost my manual
Posted on Jun 15, 2010
  • 47 Answers
SOURCE: Have to turn coffeemaker off/on to brew complete pot
The thermal cutoff switch is faulty.Check this solution.
Posted on Jul 10, 2010
freetek
  • 5568 Answers
SOURCE: my black and decker coffee maker will not turn on to brew coffee
All coffee-makers are provided with a thermal fuse located near the heating element and in series with the element itself.
This device is bullet-shaped with one lead connected to the case, the other insulated from it.
If there was no protection of this kind, it could lead to a fire if the heating element fails to get turned off when reaching its design temperature and nearly impossible to buy as a replacement part.
These are not user replaceable and both the thermal fuse and the bimetal switch that controls the current for the heating element have become increasingly less reliable as they are made in China and since we have little alternative, we have to either keep track of our warranty or just throw it away when it fails.
The fuses can fail at any time and I have brought back three coffee-makers in a five day period, all with the same failure, before giving up and getting a refund.
Another type of failure, namely of the bimetal switch occurs over time and reveals itself by the ever-longer brew time that is unaffected by dissolving the lime in the system.
The heat sensitive metal switch part becomes gradually less responsive causing the machine to just cough instead of pump as when new.
The last one I tossed had reached 40+ minutes per pot.
Posted on Nov 27, 2011
  • 3 Answers
SOURCE: How do I program a Black and Decker Smart Brew
http://www.useandcaremanuals.com/pdf/DCM2500,DCM2500B,DCM2500K884.pdf Here's a link to the manual Mjd944
Posted on May 08, 2012
Black & decker spacemaker odc coffee maker won't brew
Could be for several different reasons. You need to be more specific about what you are doing and seeing (or not seeing).
Jul 14, 2014 | Black & Decker Coffee Makers & Espresso...
Lost the valve from the water reservoir
Try black and decker's website and or contact customer service, They can tell you where to get replacement parts. Good luck.
Oct 16, 2012 | Black & Decker Brew N Go DCM18 Coffee...
My black & decker coffee machine stop brewing coffee, sound like is going to keep working but is not .
Does the display work? Does the platter heat up when it is turned on to brew? If yes to both, this string might address the problem. Email me at the posted address if you need the part.
Jan 10, 2011 | Black & Decker Spacemaker 10-Cup Coffee...
I just have the regular Black & Decker coffee maker and I have the water in it and the filter with coffee, everything you are supposed to do. It used to work just fine and then one day it stopped...
Sounds like you might have coffee oil build up. I would suggest soaking the Brew Head Screen, unscrew from the brew head where the coffee oils come into contact with machine, and filter holder in a coffee oil remover or dezcal.
Remove the screw if your filter basket has one and do not screw too tight when putting back together or it will happen again
Dec 10, 2010 | Black & Decker Coffee Makers & Espresso...
Looking for the on/off switch
I've replaced the power switch/button on a Black & Decker SmartBrew coffee maker (DCM2000).
I used an illuminated rocker switch from NTE Electronics rated at 16A @ 125 VAC, part number 54−531.
This switch cost me $3.12 CDN + taxes.
http://www.nteinc.com/switches/pdf/illuminated_rocker.pdf
The pinouts on this switch are the same as the rocker switches/power buttons used in the basic Black & Decker Smartbrew coffee makers.
You can simply cut out the old switch and attach this one to the wires in the same order, as indicated by the square notch on the body of the switch/gold terminal.
May 19, 2010 | Black & Decker Smart Brew Plus 12 Cup...
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
27 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
iandunn_tms
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
