Question about Kenmore 35912 / 35913 Progressive Upright Vacuum
Light will come on but vacuum willnot - Kenmore 35912 / 35913 Progressive Upright Vacuum
I have a bissell proheat and it willnot release water to small toolbrush for sofa
This is most likely an obstruction in the spray nozzle. Get a paper clip or if the clip is to big, use a staple and poke it through the hole in the spray nozzle. You may have to pok it from the inlet side because of the angle of the spray deflector.
Mar 07, 2017 | Bissell Vacuums
Nilfisk 150.2 willnot dispence soap when jetting
i have some bad news for you. when using soap not recommended by the manufacture, and you use the machine and use another type of soap or cleaner after you do not run water through the machine to clean the tube and sprayer out of soap the soap drys up and kluges the tubes and the sprayer, and you have to take it to be repaired or buy a new machine. i can test to that the hard way i loaned mine out and it was returned dirty and soap was dried up inside the tube and jets, look at the tube if you see dried up bubbles than the machine needs to be repair and service, service center , sew and vac one place vacuum dealer
Feb 28, 2015 | Nilfisk Vacuums
Should my dehumidifier be blowing air out? It is also not collecting water?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 17, 2011 | Maytag Vacuums
While cleaning with the floormate the dirty fluid dropt out and it willnot pick up.
sounds to me that something is blocking the suction from the impeller. You might just have to lay down some newspapers and go to town cleaning the unit. Remember it is a machine, and it has to be maintained.
Mar 04, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Cleaner willnot dispense water and vaccum it again. Soap dispense fine. would like a owners manual.
sounds like you have a clog in the waterline, or a pinched hose.
Locate the water line hose, disconnect, and blow through with can of compressed air.
If nothing goes through...you have a blockage/pinch.
Sep 18, 2009 | Bissell 1699 ProHeat Clear View Upright...
We replaced the motor on our electrolux epic 6500 but the temperture light comes on and machine willnot run.
Check for blockage in the hose or the sweeper. Check the filter located under the grill on the top back of the machine.
Jun 15, 2009 | Electrolux Epic 6500 Vacuum
Clean water tank
Will the water come out of the tank when you depress the valve at the bottom og the tank? The tank sits on a resevroir asm., is the seal on it, black and round. Inside the handle is a rod, so when you squeeze the trigger, it pushes onto the reservoir to release the water, check to be sure it is, if not then you have a problem inside the handle or a bad reservoir asm. is bad.
Feb 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Won't stay on!!! HELP!
It is the on/off switch that needs replacing. It can be done at home if you know someone who would attempt it. Overall, knowing that it is the switch, it should save money by not having them troubleshoot further. Tell them what I told you and it should be cheap. Good Luck.
Nov 20, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
HOOVER STEAN VAC 2 DEEP CLEANER
If you used any other cleaning solution other than Hoover, your Steam Cleaner will develop deposits in the turbine that drives the brushes. What happens is this:
Users pour other store bought brand cleaners in the reservoir to clean. Then they store the Hoover Steam Vac. While sitting in storage, the residue dries in the turbine and develops hard deposites, which ruins it. It will cost you about $100 to have the Hoover Store repair.
Cleaning Solution:
http://www.amazon.com/dp/B0002B8L26?smid=ATVPDKIKX0DER&tag=yahoo-kitchen-20&linkCode=asn
Oct 14, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
19 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
