Question about Canon imageCLASS D530 All-in-One Laser Printer 26 PPM, 600x600 DPI, B&W, 64 MB, PC/Mac
Want to know how to change mp tray to drawer 1 for to print from drawer 1
2 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Posted on Aug 29, 2008
MF4350d 1page only
You must check the paper settings, Canon MF 4350d have two trays, the Cassete/Drawer & MP tray or (Multi-purpose tray).
Go to Paper Settings found the panel of the Printer, Set Cassete tray as A4 or LTR size & MP Tray as Long size or Foolscap(FLSP).
You must go to Start>Devices and printers>Right click the Printer>Printer Properties>Preperences>Page size change to Letter>Apply and press Ok..
Make sure that everytime you print,it will match the paper size you want to able to use,..
Jun 07, 2014 | Canon ImageCLASS MF4350d Laser All-in-One ...
We are getting an error that says Change MP Feeder C5 on our Dell M5200. It will not print.
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Jul 21, 2011 | Dell M5200n Laser Printer
Manual feed isnt working. once tray 1 is open i thought it would automatically know i want to use manual feed.
Not necesarily so, it depends on how you have the printer configured. To test the MP tray, use the arrow keys to get to troubleshooting menu, press check, use arrow keys to get to paper path test, press check, set tray option to tray 1, then print test page. Printer should feed from MP tray. If it does, then the problem is that you do not have the printer set to print from MP tray first or you have the tray options set to exclusive which means that if your print job asks for tray 2 then printer will not print from MP tray unless you specify MP tray in the print options.
Mar 18, 2011 | HP LaserJet P4015 Printer
I want to put 8 1/2 by 11 paper in top drawer (#1) and use 8 1/2 by 14 in lower drawer (#2) I do put the papers in correctly, but it does not recognize drawer #2 as anything but 8 1/2 x 11. How do I...
First you have to put a little wheel (in front of the tray) in the correct size and format of the paper.
Than You have to see in the menu what is selected.
User tools.
System sittings
Tray paper sittings
(change to your needs)
Feb 18, 2011 | Ricoh Aficio MP 1600L Black and White...
Paper not pulling from tray 2 when tray 1 empties - Lexmark T654
For the majority of the Lexmark printers, all that needs to be done is to set the paper size and type the same for each drawer. Example - drawer 1 & 2 sizes are set to letter, drawer 1 & 2 paper types are set to plain. Set up this way, when drawer 1 empties, the printer will automatically switch to drawer 2 to supply the paper.
May 20, 2010 | Lexmark Office Equipment & Supplies
When I press print, it defaults to the mp tray feed. It shows in the screen that the default is the tray 1, but it goes to the the MP tray instead.. how do i fix this?
While I'm not familiar with the T632, I have a C782 with the same problem. I, too, tried changing the Paper Source settings with no help. Instead, I went to "Settings" then "Copy Settings" and then changed "Copy to Source" option to the value of "AutoSize Match". This fixed both our copy and print problem. If your printer does not double as a copier and does not have this option then I don't know what to do.
Feb 19, 2010 | Lexmark T632 Laser Printer
Kyocera FS-2020D won't print
You have to go to setting to change the cassette paper size , what happen is : in the setting that cassette has different size value, so when you try to print A4 it ask you to load it in the bypass or the Mp. all what you have to do is: go to cassette setting or comon setting and change the cassette siz to A4, and it will fix your problem.
Thanks for using Fixya
Oct 08, 2009 | Office Equipment & Supplies
Lexmark T630 error message: Change MP Feeder
Sep 15, 2009 | Lexmark T630 Laser Printer
Can't get transmission report on bizhub 250 to print in Portrait
to change the tray that reports print from
it can be changed in service mode soft switch 323
change bit 7 to a 1 to print from tray 1
change bit 6 to a 1 to print from tray 2
bit 5 to 1 to print from tray 3
bit 4 to 1 to print from tray 4
bit 3 to 1 to print from bypass tray
Mar 19, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
Canon imageCLASS D530 All-in-One Laser Printer 26 PPM, 600x600 DPI, B&W, 64 MB, PC/Mac Logo
13 people viewed this question
old marine
old marine
