Question about Singer Sewing Machines
Touch and sew 600 replace reel holder
I do not know how to replace reel holder what is the right position.?
3 Suggested Answers
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
SOURCE: HI The reel holder
try sewingpartsonline.com
Posted on Nov 27, 2010
Elna Pro 4DC reel holder - Elna overlocker Where can I buy it?
Try an Elna dealer. If you have difficulty finding a replacement, sometimes you can adapt something else to work like an old plastic drinking straw, a chop stick, etc.
Mar 03, 2017 | Elna Sewing Machines
I can't seem to get the bobbin holder in there correctly to get the machine to sew properly.
While I know it can only go in 1 of two ways, maybe the problem isn't in how the bobbin is in, maybe it is the route of the thread.
My assumption is you don't seem to pick up the bobbin thread and it bunches. If so the carefully follow the thread to needle you may have by passed the place you put that thread so it maintains tension.
Check that carefully, sometimes that gets overlooked.
Jan 16, 2015 | Sewing Machines
Bobbin holder does not spring across
Well its just a spring affair, if you have some mechanical knowledge or experience is in fact simple to replace. However, if you have not service your machine for quite some time, might as well get it done by your local technician plus general service on your machine as well.
Jan 11, 2014 | Singer 2250 Tradition
Where can I buy a spindle for large cotton reels?
Try an industrial sewing place. Google "leather sewing machine company. Cobra" The resulting page will have leather sewing machines but they also have the spool holders you are looking for. They just screw right on to your table, mine holds up to 2lb spools of thread.
Oct 31, 2012 | Sewing Machines
Can the light bulb on the Pfaff 7570 be changed without the bulb changer tool?
Yes. First turn off the machine. You need to get out the cover (cap) with the stitches number in it. Move the bobbin winder to the position to full a bobbin. Unscrew the screw near the bobbin winder. Next unscrew the screw near the thread reel holder. Pull up the handle to carry the machine and now put up this cover. Unscrew the biggest screw at the left hand, just unscrew a little. I'ts a little more down. Then pull up the cap at the left hand (the cap that have the thread trimmer). Now change the bulb and put all the caps to the right position. I hope that you understand me, my first language is spanish.
Dec 08, 2010 | PfaFF Creative 7570
My Husqvarna Designer I has an upper thread tension problem... the thread gets "caught" right at the beginning point of the threading process and the machine comes to a dead stop. There's major bobbin...
My guess is that it is the thread spooling off the reel that is the problem. Some of those specialty quilting cottons come on reels with plastic ends that have rough spots particularly knicks where you are supposed to "park" the thread end when you are done sewing. Run your fingers around the rim at each end of the reel and choose the smoother one to be the one closest to the threading mechanism. If neither end is suitable, flip the spool holder upwards so it is standing at a right angle to the machine, make sure the large spool holder is on then put the thread on - you won't need the smaller spool holder on top. Let the thread feed off from the right-hand side i.e. "under" the thread spool, across to the tension disks etc. Also be sure that the thread is not jumping out of that first thread tension slot.
Apr 26, 2010 | Husqvarna Designer I
The needle goes down and jams immediately
the problem of your machine is your needle it is not in her right position, and adjust your tension.
Mar 30, 2010 | Singer 3820 Mechanical Sewing Machine
Thread breakage sensor
Select in the main Futura menu Help->Machine setup Tutorial, lesson 10b, the balloon shows the proper position of the upper thread inside sensor checked area.
Sep 24, 2008 | Singer CE-100 Futura Computerized Sewing...
Needle won't pick up bobbin thread - HELP!!!
I recently fixed my wife maching with the same problem. I found that the screw had come loose that holds the linkage together that rotates the bobbin holder. I was fortunate enough to notice the screw while looking at the machine. To replace it requires taking both the front and back covers off of the frame since the bobbin holder linkage is in the rear behind the needle area. Be careful to insure that the plastic toothed "rail" that runs the bobbin holder is positioned properly or it may break off a tooth. Once I replaced the screw and put the machine back together, it picked up the thread with no problem. Hope this helps.
Dec 27, 2006 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
12 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
