Question about HP Compaq dc7100 Small Form Factor PC Desktop
Hp compact dc7100 - HP Compaq dc7100 Small Form Factor PC Desktop
LOOKING FOR HP COMPAQ DC7100 SPF Ethernet Controller
Go to this website:
HP Compaq dc7100 Minitower Drivers
Select your operating system.
You will then get a list of driver options. You will need to know what network interface you have to select the correct one.
Thanks for using Fixya.
Nov 12, 2010 | Compaq dc7100 Minitower PC Desktop
Picked up a HP dc7100 but will not boot from sata
You should have an option on the dc7100 in bios to enable sata in the devices section. Mine always worked fine with sata. If nothing else works remove the security chip, reset the cmos and reboot with the Hard Drive connected and it should connect. If that doesn't work Try flashing the bios just in case it got corrupted.
Mar 12, 2010 | HP (REFURB) HP DC7100 XPP P4 3.2GHZ 80GB...
Hi. I need to purchase a DVD burner for my Compaq dc7100 and need to know what brands will fit my computer. Thanks, **** P
I've checked on the specs of dc7100, and it shows that it has multibay optional for 12.7mm removable drives .
I've difficulties finding the exact DVD compatible for dc7100 since it seems that it's already been discontinued.
However, these are the closest match that I've found. Kindly click to double check the specification if it matches your computer:
HP Multibay DVD+RW Drive
HP Slim 8x SATA supermulti LightScribe Drive
Oct 29, 2009 | HP Compaq dc7100 Ultra-slim PC Desktop
HP dc7100 Windows Key won't work
Call Microsoft, and they can straighten out the problem for free.
Sep 27, 2009 | HP Compaq dc7100 PC Desktop
Hp dc7100 alarm on start and does not boot
Check CPU and memory seated correctly, may have overheated so check fans working and heatsink clean of dust etc.
The led should flash an error code. The number of flashes says what is wrong. There are some 9 codes, from bad to disasterous!
see
http://www.dectrader.com/docs/set1/emr_na-c00278580-1.pdf
Apr 01, 2009 | HP Compaq dc7100 Ultra-slim PC Desktop
I want free dc7100 lan drivers
Hi Zain,
Try downloading the drivers here. Copy and paste this link into your browser. Scroll down and find your network card and get the drivers from there.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=402165&prodTypeId=12454&prodSeriesId=402163&swLang=13&taskId=135&swEnvOID=1093
Mar 04, 2009 | HP Compaq dc7100 Small Form Factor PC...
HP Compaq dc7100 Small Form Factor PC Desktop Logo
19 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
