Question about Brother Office Equipment & Supplies
Won't feed paper to receive fax - Brother Office Equipment & Supplies
jimnfl
  • 17 Answers
SOURCE: outgoing fax does not feed automatically
I don't know any specific info related to the panasonic fax, but here is some "general" information that is usually universal. The fact that the paper feeds "with some help" indicates that everything is working... just not as well as it should. Very often, a problem like yours can be rectified by simply cleaning the original take-up/in rollers with some alchohol (I usually use 90%+ rubbing alchohol as it evaporates quickly and leaves little, if any, residue) on a rag. Also, there is usually some sort of "pressure pad/roller" (sometimes called a retard pad/roller") on these types of machines that work in conjunction with the primary original paper take-up roller. It can be either dirty or worn as well. This should also be cleaned. If it's a pad type system, often it just clicks/clips into place, and can be removed, the rubber pad itself flipped over in the retainer, re-installed, and the "un-worn" side then faces the paper offering better pressure for feed, and preventing multiple page feed. Hope this helps.
Posted on Jan 27, 2007
checkitright
  • 1362 Answers
SOURCE: Fax received is all black
try and make a copy how does it come out? if black the poblem is most likely the thin strip of glass, it's either dirty or not working
Posted on Dec 12, 2007
SOURCE: not feeding paper all the way
Never use Alcohol on rubber feed rollers. I am not sure what the fix is for your problem, but if you use alcohol on your feed rollers you will have another problem. Alcohol removes moisture from rubber, over time the rollers harden and will need to be replaced. DO NOT USE ALCOHOL ON RUBBER.
Posted on Jun 16, 2008
checkitright
  • 1362 Answers
SOURCE: HP fax 1020
try cleaning with alcohol if it doesn't work then yes it needs to be replaced
Posted on Aug 12, 2008
SkyR
  • 12 Answers
SOURCE: All faxes get paper jammed in the back or no paper
power off the unit, check for foreign objects inside the printer. power on the unit. try to photo copy. for the fax,fax settings must be configured. ecm and v.34 must be off. also check if the phone line from the wall jack if its connected to the line port.
Posted on Jun 17, 2010
I get plain paper or double when I received fax from my uf5300 laser fax.it print one page from 5 pages that sent and I got empty pages and double somtimes
Paper feed rollers and sheet feed pad dirty. Feed roller on top pad should be just below. Clean with alcohol. Papers have clay in them. Recycled is worst. It will glaze the pick up roller and pad.
Sep 21, 2014 | Panasonic PanaFax UF-8000 Laser Fax
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
The copy/receiving function will not work.
hi,clean feed roll if the feed roll out of use please replace it.
May 14, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
When receiving a fax, it seems that several pages of paper always
you mean you're getting 1 or 2 extra sheets when machine is printing faxes? Feed roller and separation pad that pull paper from the tray are worn.....cleaning will help in the short term.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
Fax double feeds sheets
This may occur if:
-the paper is too thick or too thin
-the roller mechanism is not properly aligned or has worn out
-the sheets of paper stick together
things you can try:
-unload the paper in the main tray and bend the stack of paper to loosen it up. Reload the paper to the main tray
Hope this helps!
Feb 17, 2009 | HP 1240 Plain Paper Inkjet Fax
Having trouble sending a fax and receiving one,, also where does
To send a FAX load the pages in the auto feed tray on the top of the unit. To receive a FAX, load the paper in the paper feeder vertically on the back of the unit. Suggest you consult your users manual.
Jan 19, 2009 | Epson Stylus CX9400 Photo Printer
Whenever I send a fax on my brother intellifax 2820 it feeds crooked, I can not get it to go in straight. Therefore, the receiver only gets half the fax.
what you will need to do is go to a hardware store and purchase some isoprophyl alcahol. put some on a rag and clean the paper feed rollers if that fails there must be some in side that area like a peice of paper, try cutting a file folder to 8x11 in manually force feed thru a the paper feed section. good luck brother tech
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
We can receive but won't take the paper to send a fax out
You have an ADF paper feed problem, try taking some rubbing alchoial and clean the ADF paper feed tires, This helps the paper to feed into the scanner unit so the fax can be sent. I have also seen part of the ADF feed unit broken.
Does the paper feed in but not transmitt out?
Aug 28, 2008 | Sharp Office Equipment & Supplies
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
