Question about Makita HR2450F Rotary Hammer
No power at switch lead and fuse ok - Makita HR2450F Rotary Hammer
Will not turn on power lead ok and power to unit and fuse appears ok
There might well be a fuse. Look around the area where the power cord goes in and around the transformer.
Jan 27, 2016 | Panasonic Audio Players & Recorders
2004 toyota tacoma windshield wiper switch or motor
If you have interval wipers, you need to check the 10A GAUGE fuse and the 20A WIPER fuse. If OK, check for power output from the combination switch. Washer-wiper action is synchronized so that washing occurs before wiping but the wash action can be skipped. You can check for power across the BLU and BLU/ORG leads of the washer motor and the RED/WHT and BLU/BLK leads of the wiper motor if you suspect toe motor(s) are bad.
Sep 17, 2012 | 1994 Toyota Pickup
My 1990 ford f150 has power doorlocks and the switch on neither door works, but the power windows work. I checked the fuses which are all ok what else can be the problem?
Hi..your power windows operate through the ignition system and acc modes. Your door lock power source comes straight from the battery. If you have checked your door lock fuse in the fuse panel and it checks okay, then the next step would be to trace down the fusible links leading from the battery. I believe you will find one on the starter solenoid leading to the alternator and 3 more links behind the battery. If you have a voltmeter you should be getting 12 volts on one side of the door switch. If this is the case and the lock does not work, you could have a bad switch. Since you said neither switch works then chances are you aren't getting voltage through one of the fusible links. Hope this helps.
Jun 20, 2011 | 1990 Ford F150
No heat changed heating element still no heat
Make sure you are getting 220AC volts at the terminal post at the machine then make sure your neutral (ground ) at the terminal post is good. Use a multimeter or "wiggy" to check. First check  for 220 by putting meter leads onto the hot leads. Then check for 110 volts by putting one lead on a hot wire and the other to the middle ground wire then switch to the other hot lead and ground. If this checks out then power is ok. If not check breaker or fuse box. If power is ok then it could be on oh the thermals, the round silver looking things with a wire on each end . They must have continuity thru them for power to flow.
Sep 23, 2009 | Kenmore Dryers
Hi i have a 1998 jaguar xj sport v8 the problem is i went to start it the ignation lights came on and then went of now i have nothing i checked the battery it is ok i checked the main fuses in the boot...
check all leads coming from the battery with an ohm meter, should read zero, no resistance, make sure you do this test with the battery dis-conected otherwise you can burn out the meter or the fuse in the meter. if you need more help get back to me
May 15, 2009 | 1987 Jaguar XJ6
Rear lights not working
Check the lite bulbs, and fuses. If OK then move to the grounds and power leads. Clean with sand paper. Check for power at the brake lite switch and through the switch also.
Mar 07, 2009 | 1995 Jaguar XJ6
Sky box will not switch on
Hi
I know this sounds very obvious, is there power at the wall outlet?.
(In the UK,) has the fuse in plug top blown?.
If both above ok, check fuse inside sky box. IT IS IMPORTANT THAT YOU MAKE SURE THE POWER LEAD IS REMOVED FROM THE SUPPLY. Remove screws from sky box cover and remove top, around where lead enters the unit you should find a glass fuse, if this has blown it should be replaced with identical value fuse as that which was originally fitted, failure to do this will cause ireversable damage.
Good luck
Nov 29, 2008 | Televison & Video
My indicators and hazard warning lights have both suddenly stopped working have checked all fuses all seem ok
I think there is an issue with turn signal switch, test the leads at the switch that are supposed to have power, if they are ok replace the switch. An inexpensive test light will do nicely for these checks.
Aug 21, 2008 | Alfa Romeo 156 Cars & Trucks
Makita HR2450F Rotary Hammer Logo
63 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
