Question about Ativa AVR1 Digital Answering Machine
Manuel for avr-4
Change the time
I need manuel for denon 1604
You can download the manual from the manufacturer's web site at
http://usa.denon.com/US/Downloads/Pages/InstructionManual.aspx?FileName=DocumentMaster/US/AVR-1604_684_ownersmanual.pdf
If FixYa screws up the formatting, it's
Jul 12, 2010 | Denon AVR-1604 Receiver
Requires operator manuel
You can download the manual on the link below. Just click on the PDF.
http://safemanuals.com/user-guide-instructions-owner-manual/DENON/AVR-2800-_E
Good Luck and please rate 4 thumbs up for the free answer
Apr 29, 2010 | Denon AVR-2800 Receiver
I purchase a microwave which is 240v 50z but in my country we usually use 230v 60hz, can i use AVR to solve my problem?
Hi. An AVR (auto voltage regulator) will not change the freqs from 50 Hz to 60 Hz. An AVR only changes voltage. The frequency in is the same frequency out.
Having said that.... I don't think your going to damage your unit as long as you don't run it for long periods time. I live in the tropics and use 4 different AVRs myself. I have had both 50z and 60 hz electronics and appliances running fine on 60 Hz for the last 7 years. Your call! Hopefully this was useful information.
Jan 14, 2010 | Microwave Ovens
How to set time and date on Ativa? AVR-4 Digital Answering System?
how do i program my phone to show name and phone when someone is calling and how do i change time nad date and year i have a ativa digital answering machine
Aug 21, 2009 | Lands Phones
Lost manuel for Ativa AVR-4.
You may acquire a copy of the manual in pdf form.
Click Here!
Or Here!
It is the fully authorized Ativa AVR-4 answering Machine handbook from Ativa on 03/22/09
Jan 08, 2009 | Office Depot Ativa D5772 Phone
Manul denon avr-1601 en castellano
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Espagnol as well ...I think
Dec 12, 2008 | Denon AVR-1601 Receiver
I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Dec 08, 2008 | Harman Kardon AVR 235 Receiver
720p output doesn't work
The problem might be that the set can not handle the change in signal. Try setting the AVR-247 to 720P first then turning on the set. Or manually set the TV to receive 720P then change the AVR. TI believe that you have a connectivity issue where the two units are not speaking the same language at the same time. Update this with your results and please post the TV make and model.
Thanks,
Dan
Apr 01, 2008 | Harman Kardon AVR 240 Receiver
Harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
May 07, 2007 | Harman Kardon AVR 240 Receiver
Ativa AVR1 Digital Answering Machine Logo
55 people viewed this question
Top Ativa Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an Ativa Lands Phone Expert? Answer questions, earn points and help others
