Question about LG LRFC25750 Refrigerator French Door
How to unplug frozen drain holes - LG LRFC25750 Refrigerator French Door
Frige part bottom shelves get frozen water and ice dosent work
This is a known problem. Samsung knows about this and if you call them they may come out and fix it for free. Otherwise, the water tanks are frozen along with everything else. Unplug the machine. Take the vegetable/salad draws out and you will see the water tank. You need to unscrew this and lay it against the inside of the fridge. Now remove the lower half inside back panel by the six screws, two will be behind the vent like plastic covers. Unplug the two juction boxes and remove the back cover. You will find that everthing is frozen, take a hairdryer to the lot of it including the drain away hole at the bottom of the lower half. re asemble and all should be ok......until the next time. Ensure you completely unfreeze the drain away or you will get water leaks.
Jan 26, 2014 | Samsung Refrigerators
Leak from the freezer into the frige. Frozen hose
The first guy was right. The drain hole is blocked. You probably spilled an ice tray in the freezer or something. Easy fix is to empty the freezer and unplug for about 4 hours to make sure all ice in the freezer melts . Now its the ice under the freezer deck thats blocking the drain hole. Thats why you need to leave the freezer off for so long.
HID KITS.
Jun 01, 2012 | Whirlpool Refrigerators
Kenmore refrigerator, model #60267990, serial # EJ5036206, water leaking from the freezer into the fridge on shelves into veggie bins, drain hole freezes up, defrosted it about 2 months ago, and has...
a plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs. Folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Feb 28, 2011 | Kenmore Refrigerators
We have a LG french door refrig, Model #LRFC25750TT. Ice forms in the bottom of the freezer which causes the door to stick when opening and closing. It appears that water may be coming from the vent on...
You have a frozen drain tube. Remove the back cover after unplugging the unit. Locate the drain tube running down to the drip pan. If it is frozen, thew it with a hair dryer. In the inside, find the drain hole and pour hot water in it until it drains properly. I f it happens again your defrost element is too far away from the aluminum drain pan and needs to be GENTLY lowered closer to the drain
Dec 03, 2010 | LG LRFC25750 Refrigerator French Door
Water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
Nov 03, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Leaking in the bottom of the freezer side
Plugged up drain. Unplug refrigerator. Remove basket at bottom of inside freezer ( it may be frozen in ice) . Get your hair dryer and thaw and remove all ice, At the very back bottom of inside freezer is the drain that is plugged up. You will see a hole, pour hot water into it. You may need to snake a flexible piece of wire through the hole. Once water goes down its open. Worst case you may have to remove drain tube in back bottom and clean out. Hope this helps
Refrigerator Repair
Oct 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Water frozen in bottom of freezer. after frozen over bottom will come out into floor in front of freezer door help!!! will get ice out of bottom of freezer and no water in floor . there is a hole in back...
follow the floor to back and you will find a trough with a hole in the center..it's clogged..a semi stiff wire or I use flexible tubing and run it down the hole to clear blockage..run hot water down it to check it is clear.
Jun 12, 2009 | GE GSH25JFR Side by Side Refrigerator
Water coming out of the freezer compartment into main unit
I believe the drain is blocked behind the panel wall inside freezer. You will need to unplug the refrigerator and remove panel and inspect drain at bottom of evaporator. There is a tray with a drain hole on the low end. Also check around area that water enter from back of refrigerator to ice maker. Let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Roper frig, freezer on top ,frozen under tray.water in bottom of frig
sounds like you have a frozen defrost drain. This is a fairly easy repair you can do yourself.
that should fix you up. if you have any further questions leave me a comment here and I'll gladly help any way I can. thanks Peytonreassemble in reverse order
Feb 23, 2009 | Whirlpool Refrigerators
Ice acculumates in the bottom of freezer
Defrost drain tube is plugged. Drain is a round hole about the size of a quarter below the evaporator coils. (behind back wall of freezer.) Take a turkey baster with hot (not boiling) water and shoot it into the drain hole until water runs through it (into drain pan under refrig.)
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LRFC25750 Refrigerator French Door Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
