Question about Ematic Tablets & eReaders
Can't reset tablet
I hold down the power button and nothing happens
jmernst
SOURCE: my coby kyros mid 1125 want unlock when i try to slide the unlock slider nothing i've tried to power down it want let me do nothing help please!!!!
Have you tried taking the battery out? That solves a lot of problems.
Posted on Dec 27, 2011
andrewpwrp2p
  • 229 Answers
SOURCE: i want to reset my daughters android tablet 4.0
To reset the tablet, you're going to have to do what's called a factory reset. To do this go into the settings, and look for tablet information. Under that it should contain a factory reset button.
Posted on Feb 26, 2013
giao_mai
SOURCE: My Samsung Galaxy Tab won't turn on, even though battery is full. What's the problem?
hi did you fix your problem?
Posted on Mar 06, 2013
SOURCE: I want to hard reset
how to hard rest Samsung Galaxy Tab Tablet PC
press and hold -sound and power for 5 second you well open recovre mod press hard reset and press the long words and write yes the phone well restart and well pe in factore mod
Posted on Jun 05, 2013
benjamin_951
  • 53 Answers
SOURCE: my tablet is not powering on..it is getting charge
Two most probable problems:
-bad battery
-bad motherboard
If it's still under warranty, get it repaired.
If not, buy a new one
Posted on Oct 13, 2013
Allwinner a33 tablet wont charge or power on
Plug the tablet in, and try holding volume up + power buttons for 15 seconds or until something happens. If nothing happens, try holding volume down + power buttons for 15 seconds or until something happens.
Dec 13, 2016 | Tablets & eReaders
I have a Polaroid 8 inch tablet A8.What will happen if I reset it to factory settings?I can not get into anything now,it does nothing. Thanks!! for any help :-
Hi turn tablet of then try holding down you're power button & the volume up button at the same time to see if it will reboot:::,if the tablet has been corrupted u might have to do a factory reset.. good luck
Jun 22, 2016 | Polaroid Tablets & eReaders
How do I turn on my pandigital supernova tablet?
It could be two things, Jack: I would start by plugging it in to your charger for about 24 hrs to make sure it's not just the battery after that length of time not being used...OR, you might have to reset it to factory settings.
In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults.
First you need to make sure your tablet is powered off.
Hold down on the Volume + button and hold down the Power button at the same time.
  • As soon as the tablet's screen turns on, let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
  • At this point you will see a screen with boot options.
  • Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option.
  • On the next screen use the Volume - button again to go down to Yes and use the Power button to select.
  • At this point it will be going through the wiping and resetting process.
  • When it's done you will see the first screen you came to when you first started the setup.
  • Just tap the Power button to select Reboot System Now.
Stuck in Android System Recovery Tips to Fix Recover Lost Data
Apr 27, 2016 | PANDIGITAL SuperNova
Nobis tablet stuck on go
try holding power button in for like 30 seconds to completely down power tablet
Jan 02, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
Why is my maxtouuch android tablet stuck on start up screen
has the tablet got a reset button hole if not try this ..try holding the power button down for about 30 seconds to c if it will reset if this does nothing hold down power button and volume button at the same time for 30 sec or more. good luck
Jul 11, 2014 | Tablets & eReaders
I have locked myself out of my tablet
You will need to do a factory reset:
Oct 29, 2013 | Proscan Recertified - PLT7035 4GB NAND...
I have forgotten my pin code for my supersonic SC-74MID tablet. How do I reset it?
I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
Jan 08, 2013 | Supersonic 7" Touch Screen MID Tablet
Tablet wont boot into anything but screen with horizontal lines..just got it today and charged battery and now i get nothing?
Holding the power button down for 10-15 seconds is considered a hard reset on most tablets. If it still won't load you can try doing a factory restore.
  • Make sure the tablet is powered off
  • Briefly tap the power button once, then hold the power button and volume down until you get the boot menu
  • There should be an option to factory reset or something to that affect
Dec 08, 2012 | Tablets & eReaders
Tablets & eReaders Logo
27 people viewed this question
Top Ematic Tablets & eReaders Experts
Ap12
Ap12
Michael Harrier
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
