Timer wont advance automately on estate heavy duty washer works fine when advanced manuely
gwshaw71
  • 83 Answers
SOURCE: Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Posted on Nov 30, 2007
  • 185 Answers
SOURCE: kenmore heavy duty 70 series washer
put a new timer in it
Posted on Mar 24, 2008
  • 52 Answers
SOURCE: washer leaking from bottom
Take the front panel off of the washer, and run it through a cycle. Watch to see where the leak is coming from. Also, pay attention to the drain in the wall when it is in spin/drain. If this has a blockage in it, it might be backing up causing water to come back out of it.
If you see no leaks the next time you run it, it's possible that it splashed over while spinning because of the off balance load and may not happen again unless it becomes off balance again.
Posted on Apr 04, 2008
  • 110 Answers
check your run capicitor
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Jun 01, 2008
  • 130 Answers
SOURCE: Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Posted on Jan 24, 2009
Washing machine does not advance cycles automatically
More than likely a bad timer. You can buy the parts on-line, one source is repairclinic.com. Go to that page and enter your model number and look for timers. I found several there for your machine depending on the options the machine has.
Jul 04, 2014 | Kenmore Washing Machines
I have a Frigidaire Gallery Heavy Duty electric dryer, the dryer run non-stop even on auto-dry mode (timer doesn't advance) but the clothes aren't drying either.
Timer will not advance unless the element is working. Suspect bad element or bad thermal fuse on element housing
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Washing Machines
GE Top loader, Heavy Duty, large capacity washer does not advance cycles but stays in one cycle. I have to manually change cycles.
Depending on the exact model number it sounds like you are dealing with a bad timer or bad clock on the timer. There are contact points inside the timer and they burn out. Sometimes the clock goes bad It has plastic gears inside and is non serviceable. The only thing you can do is replace the timer or call a local repair technitian to make sure.
Oct 26, 2010 | GE Washing Machines
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Kenmore heavy duty series washer
you need a new timer. order part thru sears.
Mar 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
