Question about Dell Vostro 230 PC Desktop
SWITCHES OFF IN 40 SECONDS - Dell Vostro 230 PC Desktop
    Habit-Forming:
    New Friend:
  • 110 Answers
Your pc need a service. It is important that the CPU gets new cpu past every 3 months. See me on facebook for more info on how to service. Your own pc
Posted on Sep 20, 2016
My 40 inch rca scenium will turn off for a few seconds and then turn back on all by itself. When it first started it would only happen once and a while now it will happen up 4 times in an hour. Any help...
First try cleaning front Panel contact switches if cleaning them does not work then replace all 7 of them. Call Mats 1-800-628-1118 contacts are your Off/on ch- ch+ vol- vol+ menu button
Nov 22, 2009 | RCA Scenium D40W20 40" Rear Projection...
Keyless control not work
here ya go follow the steps exactly and it will work and dont forget to rate me please,
* Remote programming
Start with drivers door open, unlocked, and no key in the ignition.
Insert and remove the key from the ignition switch twice within 5 seconds.
close and open the driver door twice within 40 seconds.
Then insert the key into the ignition key cylinder and remove it.
Close and open the driver door twice within 40 seconds.
Then insert the key into the ignition key cylinder and close the door.
Turn the ignition switch from LOCK to ON and back once and remove key
Locks should cycle once.
Within 40 seconds press the LOCK and UNLOCK switches on the transmitter switch simultaneously for 1.0 – 1.5 seconds.
Within 3 seconds after the previous operation, press either one of the switches for more than 1.0 seconds.
Within 3 seconds after the transmitter switch has been turned OFF, the LOCK–UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly.
In case the LOCK–UNLOCK operation is performed twice, the registration of recognition code has failed.
Perform the registration procedure from the beginning once
Feb 03, 2009 | 2005 Toyota Camry Solara
My nokia 2610 switches off when am operating
maybe there is a virus on your phone,try scan it or format it and if the problem still come again, send it to the phone shop and ask them what is the problem..gud luck..
Oct 22, 2008 | Nokia 2610 Cellular Phone
Why does my key fob only open drivers door
this how a dealer does it:
DOOR CONTROL TRANSMITTER
REGISTRATION
1. REGISTRATION OF RECOGNITION CODE
HINT:
 The add mode is used to retain the already registered codes while registering a new recognition code.
This mode is used when adding a transmitter. If the number of the registered codes exceeds 4, the previously
registered code will be correspondingly erased in order, starting from the first registered code.
 The rewrite mode is used to erase all the previously registered codes and register only new recognition
codes. This mode is used when exchanging the transmitter or the door control receiver for new one.
 The prohibition mode is used to erase all the registered codes and cancel the wireless door lock function.
Use this mode when the transmitter is lost.
 The confirmation mode is to confirm how many recognition codes have already been registered before
an additional registration of a recognition code.
 All the following registration procedures must be performed in order continuously.
(a) The vehicle should be in the following conditions.
(1) The key is not inserted in the ignition key cylinder.
(2) Driver’s door is OPENED. (The other doors are CLOSED)
(3) Driver’s door is UNLOCKED.
(b) Perform the following operations to select the desired mode.
(1) Insert and remove the key from the ignition switch twice within 5 seconds.
(2) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
(3) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
(4) Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1
to 5 times to select a mode.(2 times for rewrite mode) Then remove the key from the ignition key cylinder.
(5) After selecting a mode, the integration relay automatically performs the power door
LOCK-UNLOCK operation within 3 seconds to inform the selected mode.
(c) Register the new recognition codes :
(1) Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and
UNLOCK switches on the transmitter switch simultaneously for 1.0 - 1.5 seconds.
seconds.
(2) Within 3 seconds after the transmitter switch has been turned OFF, the LOCK-UNLOCK operation
completed correctly. In case the LOCK-UNLOCK operation is performed twice, the registration of
recognition code has failed. Perform the registration procedure from the beginning once again.
(3) If the multiple transmitter to be registered, repeat step (c) within 40 seconds after the previous registration.
this is why the dealer charges for this
Jun 19, 2008 | 2003 Mini Cooper
Standby light flashing
I think that its some problem with your main board.so it is better to call your dealers
Nov 02, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Manual for the Protec Bytelan KVM/4
The switches are used when cascading more than a single BYTELAN KVM. It specifies the scan rate, and which KVM unit the keyboard and mouse are connected to. For a single KVM, use the default settings. SW1 SW2 Scan Rate ---------------------- ON ON 2 seconds OFF ON 10 seconds ON OFF 20 seconds OFF OFF 40 seconds SW3 NOT USED SW4 ON For KVM unit with KB/mouse OFF For other KVM units w/o KB/mouse, If your power supply isn't adequate, it may cause your KB/mouse problem. It should be 9VDC with at least 500ma. Hope this helps.
Aug 20, 2007 | Protec Microsystems Bytelan KVM/4 KVM...
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
Dell Vostro 230 PC Desktop Logo
70 people viewed this question
Alun Cox
