Question about Microsoft Xbox 360 Console
Xbox 360 overheats on startup
When I turn my 360 on,it gives the two red rights when xbox logo is displayed on screen.it happens all the time
    Sergeant:
  • 321 Answers
There could be hardware problems! mine never gave the two lights when it started it but when playing certain games it overheated and thats whats happening.. i got upset and opened mine up[ voids warrenty for three red lights] and added a 3 inch fan with a 12 v converter for its on power. i set it in on the heat sink and the bottom right corner of the xbox..
so i think you should get a powerful 3inch by 3inch fan with its on power supply and set ur xbox so you can point the fan at the bottom of the xbox! this will help! dont open ur xbox just set a powerful fan[ radio shack, walmart, hardware store] and let it cool the bottom of ur xbox!!!!!!!!
Cheapist way
!!items needed!!!
1. 12 v dc brushless fan
1. 12 volt ac power adapter that hooks up to the wall and the fan for a Direct Current!
thats it may cost over 20 and walmart is cheap and a little less quality
but as long as air pushing on the bottom of ur xbox is moving fast[ dont put the fan to close] so heat is transfered ur good
Posted on Jun 19, 2009
My xbox turns but the image docent pop out
To reset Xbox 360 console display settings
  1. If there is a disc in the console, remove it.
  2. Turn off the console.
  3. Turn on the console by using your controller. To do this, press and hold the controller's Xbox Guide button until your console turns on.
    Note If multiple controllers are connected to your console, make sure that you use the player one controller.
  4. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
  5. The console will restart and you will see the Xbox 360 logo again.
    The console's display settings are now reset to the defaults.
May 21, 2011 | Microsoft Xbox 360 Console
No video have sound when using component connection on my xbox 360 hdmi ok. help
Your resolution settings on the xbox are too high for your currently used cables or tv. To reset your console's resolution follow these steps: To reset Xbox 360 console display settings
  3. Turn on the console by using your controller (its best to have the controller plugged into the console rather than just using the wireless). To do this, press and hold the controller's Xbox Guide button until your console turns on.
Mar 12, 2011 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox 360 it turns to a black screen and says i have error E73 and when i went to Xbox.com it didnt say anything about it
Apr 14, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Apr 07, 2010 | Microsoft Xbox 360 Console
My xbox freezes and flashes red
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
Stop the heat and you will be fine.
Feb 27, 2010 | Microsoft Xbox 360 Console
Four flashing red lights, xbox worked fine lastnight
Doesn't really have to do with hdmi. They call it the red ring of death, I've had it happen to me 4 times. It's a problem that happens to almost everyone. Call 1-800-4my-xbox, "I think that's right" and tell them your problem, they fix it for free, and give the address to send your xbox to and send you a new one. Just call and they will go over everything with you.
May 05, 2009 | Microsoft Xbox 360 Console
Purple "tears" on my 360 when i turn it on, no picture.
this happens when your xbox overheats. its happened to me a few times too.
rate
Feb 04, 2009 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
XBOX 360 stopped displaying video :(
it is most likley that your cables are broken and you need new ones go to your local eb games and pick them up for 20.00$ are unplug you a/v cable from the tv and the xbox for 10secs then plug it back in and try again if that does not work buy new cables also got to xbox.com for trouble shooting tips.
plese rate
Jun 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
680 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
