Question about Sharp Office Equipment & Supplies
Sharp mx2600n service code l4-16 - Sharp Office Equipment & Supplies
    Scholar:
  • Sharp Expert
  • 120 Answers
Your machine has automatic fusing pressure. A gear on the front side of the fuser meshes with a motor gear on the inside front of the machine. Somehow this has gotten jammed or reversed. Shutting off main power without powering down from the op panel first may have caused the problem. you will need to take out the fuser, check the pressure gear for cracks, and make sure the cleaning bar roller is resting on top of the fuser roller and not jammed underneath. The flag triggering the pressure photosensor may also be in the wrong position. You will have to turn the gear until the gap is widened between the two fusing rollers before you put it back into the machine. There is a screw on the front side holding the fuser up against the pressure motor.
Posted on Apr 22, 2014
3 Suggested Answers
SOURCE: what does maintenance code DC mean on a Sharp MX2600N
http://www.printcopy.info/?l=en&mod=docs&brand=Sharp&prefix=MX&gID=19349
Above is the service manual, and below is your user manual, the information you require will be in them.
sharp-world.com/products/copier/.../MX3100_2600N_CTLG_S.pdf
Posted on Jun 22, 2010
  • 33 Answers
SOURCE: e7-06 sharp mx2600n
Decode error trouble: Compression
decode error (A compression file cannot
decompressed.)
1) Check the installing state of the PWB. (PCI bus)
2) When an error occurs during a FAX job, check
the installation of the FAX PWB. In the other
cases, check the installation of the MFPcnt PWB
and HDD.
3) Replace the MFPcnt PWB.
Posted on Jul 20, 2010
Mx2600n is having paper jam BTW the black and white roller before the Fuser unit
There are a number of reasons why the paper would jam at registration. First off, if the paper is completely flat & straight it is probably a feed issue or paper detect issue. There are 2 little black photo reflectors before the rollers in the centre of the feed path. These sensors can get covered with paper dust & may need cleaning. Also try feeding paper from the manual feed tray & see if it jams. If you have jams from both cassette's & manual feed then its most likely a sensor of feed issue. If its from one tray only then the sensors in the vertical path may be dusty with paper dust or worn pick up & feed tyres. There is also an issue with the feed clutches in the paper pick up drive unit which can fail & have been upgraded.
Secondly, if the paper is Z folded at the registration rollers but before the fuser then it could be the primary bed drive gear. This gear also drives the secondary belt unit located in the right hand door assembly.
Hope this helps.
Dave.
Jan 11, 2017 | Sharp Mx2600n Color Copier, Printer,...
What does error 85-01 mean on a sharp printer?
Hi do U mean H5-01 if so clear paper jam put it in Copy mode press on the keyboard. P * C * 14. CLICK EXECUTE and press Yes then press the COPY TAB IT should reset. Good luck
Nov 01, 2016 | Sharp Office Equipment & Supplies
What number will I use to reset the PTC unit in sharp copier mx2600n
I assume you have a C4-** code displayed.
The PTC unit is failing, if you turn the copier off & on then this will reset the machine. If the error is still there then the PTC will probably have failed & will need replacing.
Hope this helps.
Dave.
May 03, 2016 | Sharp Office Equipment & Supplies
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
How do I run a service mode to reset the machine MX2600n
press program,*,clear,enter 14 press start then turn machine off and then back on.
Nov 23, 2013 | Sharp Mx2600n Color Copier, Printer,...
Unlock password Problems for sharp mx-2300g
Here's a link to a site that has the user manual. It's free to download, but you'll need Adobe or Nitro PDF reader to open it. I found the instructions for the same thing for my copier in its' manual. Good luck!
Aug 31, 2012 | Copystar Sharp MX-2600N Copier : Sharp...
I need to add my computer on the network sharp mx2600n scanner
the default password for the afaq shamel router is :
user name=Afaq_Shamel
password=Stccpe_2009
Jul 16, 2011 | Computers & Internet
What does maintenance code DC mean on a Sharp MX2600N
Jun 22, 2010 | Office Equipment & Supplies
E7-06 sharp mx2600n
decompressed.)
and HDD.
Feb 12, 2010 | Sharp Office Equipment & Supplies
1,598 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
