Question about Vehicle Parts & Accessories
07 gmc tow mode doesnt work - Vehicle Parts & Accessories
    Sergeant:
  • 243 Answers
Check your owners manuel for a switch, if not unless you are really towing a heavy load, I would not worry about it. I never enabled the tow mode on my 07 envoy. the switch on it was on the shift lever. If all else fails, you can purchase a haynes manuel from ebay, about 18.00 and you will find a lot of great maintanence tips and help in those.
Posted on Dec 25, 2014
2002 gmc 2500hd 6.0 won't come out of tow haul mode
Solenoid inside transmission is not working
Jan 24, 2014 | GMC Cars & Trucks
Tow haul mode
ckeck all fusses &relays
Aug 16, 2013 | Cars & Trucks
Tow haul switch will not actvate tow mode / no indicator light on dash display
on shifter knob the switch is at the end. two wire are connect to it and they are cut inside column steering
i hope it help
Aug 14, 2013 | 2000 GMC Sierra
My autoride suspension on 2001 surburban only seems to work in tow haul mode. i cant hear the compressor but it handles much better in this mode if you dont use tow haul it is really soft in the corners...
The autoride is likely coupled with the tow/haul function. When towing, you want firmer suspension, tighter cornering, less sway, along with the firmer transmission shift and different shift points. This helps keep you from tipping the vehicle when you have a high load because the suspension swayed too far. The vehicle is supposed to be a luxury vehicle, so this changing characteristic allows it to ride smoother and softer when you don't need the trucklike suspension.
Nov 29, 2009 | 2005 GMC Yukon Xl Denali
Tow haul mode has no change on transmission operation. Truck barely moves a 6000lb trailer when starting off on a hill. 3/4 ton with a 6.0 and 3.73 rear end.
tow mode gives ur transmission a longer shift point to relive strain on engine while driving -it doesnt give it more horse power to start off a hill
Nov 04, 2009 | GMC Yukon XL Cars & Trucks
Can you flat tow a 2007 Lincoln MKX?
The 2007 Lincoln MKX is definitely towable "4 down". According to the owners manual: The ignition switch needs to be in the accessory position (position 2 of the 4 possible positions) so that the steering wheel is able to turn to let the front wheels track the towing vehicle. The transmission needs to be in "N" so that the engine's disconnected. The parking brake needs to be off, and the engine should be run for 5 minutes before starting out and "at fuel stops". This makes the vehicle a good vehicle to tow along with you behind your motorhome. The folks at Blue Ox make an excellent tow "baseplate" that is practically invisible yet hooks up easily to the motorhome. The BX2192 package is made specifically for the '07 to '10 MKX. It works beautifully with my '07!
Oct 05, 2009 | 2007 Lincoln MKX AWD
Towing with 2001 GMC Yukon XL
It saves your transmission from costly repairs. The little bit of fuel you think you may save by not using it, will certainly not outweigh that big bill for new transmission. Saves transmission from shifting up & down too much.
Jul 31, 2009 | 2001 GMC Yukon XL
Tow/haul light wont turn off
I have found that on three silverado's there is a plastic clamp on the bottom side of steering column where the wires become broken and can short out. You have to remove the column covers to see this, it should be claser to the lowe dash trim panel area needs a shifter to repair unless you can fix that little wire!
Apr 05, 2009 | 2000 GMC Sierra
02 gmc allison tran. wont go into tow-haul mode
THERE HAVE BEEN ALOT OF PLOBLEMS WITH THE SHIFTER HANDLE/SWITCH. THE BEST WAY TO VERIFY CONCERN IS USE A DIAG. SCANNER & VIEW TRANSMISSION DATA DISPLAY WHILE ENGINE RUNNING. THE SWITCH IN THE SHIFTER IS FAULTY. IF YOU SEE NO INPUT CHANGE WHILE DEPRESSING SWITCH THIS IS YOUR CONCERN.
Nov 08, 2008 | 2002 GMC Sierra 2500HD
99 gmc 1500 pick up 4x4
found wires broke at shifter where it hooks to steering colum pull rubber boot loose at shifter base this was on my 2000 gmc new sierra
Jun 22, 2008 | 2000 GMC New Sierra 1500
Vehicle Parts & Accessories Logo
64 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
