Question about Canon Ink Cartridge GPR15 for iR 2270, iR 2870
Ir2270 not sensing toner - Canon Ink Cartridge GPR15 for iR 2270, iR 2870
    New Friend:
  • 66 Answers
Simple That problem is in the Developing Unit. If you check the DV you will find on one side it has gears remove the screws to expose the gears. Then look for the small round copper metal in front of a gear thats your culprit. Replacing it is the best way. Or clean it if no replacing part is available.
Posted on Oct 12, 2015
My canon ir2270 is saying code error e000020-0000 please help me understand this
that error indicates that there is an obstruction between the toner hopper and the developing unit .
Feb 16, 2016 | Canon Office Equipment & Supplies
Please help me a reset key for the copier machine IR2270 wich read error code E000000-0001
The abnormal rise of temperature.May be main thermistor or dc controller pcb.You have to reset the machine in service mode COPIER FUNCTION CLEAR ERROR.
Oct 30, 2014 | Canon iR2270
How to clean error 000024-01 in canon 2270
E024-0001 Error Code:
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
However, re-attachment of the sensor also solves the symptom.
When the symptom has occurred, make the following selections in service mode [COPIER > I/O > DC-CON] and check the setting for the bit1 of [P021]. If the setting is "1", re-attach the toner sensor.
May 18, 2014 | Canon ImageRunner 2270 | IR2270 |
Error code E00024-0001 for canon ir2270
Clean DP unit (developer unit) and install toner manually Press- additional Then 2,8 ,additional press Copier ,function ,install toner ,ok if not then Replace DP censer or toner hopper censer
Nov 06, 2013 | Canon imageRUNNER C3200 Copier
ERROR E0024 FOR CANNON IR2270
check the toner hopper .toner is not being fed into the developer module at set rate.clean the hopper by blowing the toner and check the toner screw motor for rotation and do check when u install toner by service mode does the toner bottle rotate.
Aug 13, 2011 | Canon ImageRunner 2020i Copier
Canon ir2270 service manual
hello friend, you can find the canon ir2270 service manual in below link:
Canon ir2270 service manual:
http://goo.gl/LK8T5Z
thanks
Oct 11, 2010 | Office Equipment & Supplies
IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Jul 06, 2009 | Panasonic WORKiO DP-2330 Copier
Rplacing Waste Toner Container
Hello sir;The waste toner bottle right in front of the machine, when you open front door you ill see a white bottle remove and dump it out, turn power off and back on.
Apr 14, 2009 | Canon imageRUNNER 2270 Copier
A message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Apr 14, 2009 | Canon imageRUNNER 5570 Copier
Canon Ink Cartridge GPR15 for iR 2270, iR 2870 Logo
170 people viewed this question
old marine
old marine
