Question about Janome Sewing Machines
Janome 3160 top thread..
Bobbin stitching looks great but upper stitching appears to be a line of thread... This machine (Janome 3160) is only a few weeks old and has worked til now. I have had the upper thread break 2x and have had to tug it out of the machine. (a piece may still be in there?) Technican told me to open the machine & look but I could not remove the top, just as well probably. I am a 1 1/2 hr drive from dealer or I would take it in,,,help please.
  • 202 Answers
SOURCE: upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Posted on Aug 23, 2007
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 5 Answers
SOURCE: tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
Posted on Jul 30, 2009
  • 268 Answers
SOURCE: skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Posted on Mar 23, 2010
I can't get the tension right on my Janome DKS30 sewing machine. I can operate a machine but I am quite a novice. My machine is 9 months old and I have used it less than 20 times. Can you please help?
Sounds like your top tension is too tight. You may find it helpful to join a FaceBook sewing machines group to get further help. Happy Sewing!
Dec 30, 2016 | Janome Sewing Machines
I have a janome 8200, when sewing the top stitch is perfect but top thread bunch under neath and no bobbin thread appears to be used, I have changed threads, bobbins and needle,
Be sure to use a brand new needle.
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread the upper thread. This allows the tension disk to release so the thread will seat properly. Verify that the thread path is correct.
Check that the bobbin is installed correctly (turning the proper direction in the bobbin case) and the bobbin case tension is threaded correctly.
Set the upper tension to the midway point. (This is the beginning point and may need tweaking later.)
Pull the bobbin thread to the top of the sewing project.
How and Why to Bring up the Bobbin Thread P.S.--this works with regular sewing, not just for quilting.
Lower the presser foot and test your machine. Begin sewing slowly.
If there are still issues--upper thread looping, try tightening but if it doesn't improve, the tension mechanism may not be working properly. Check and remove any thread pieces or gunk stuck in the tension mechanism. If still not working, it probably needs service.
If the bobbin thread is still not connecting with the upper thread, the sewing machine's timing is most likely off. (Search the internet for "sewing machine timing." There are multiple web sites and videos available that discuss this OR take it for service.)
Oct 08, 2016 | Janome 8080 Computerized Sewing Machine
Needle stitch fine. Bobbin stitch loops.
First, try a brand new needle.
Second, consider using a better quality thread. By all means, AVOID old or bargain bin threads. Coats & Clark used to be a standard, but thread quality has improved over the past few years, so you may want to check out other brands like Aurafil, Superior, Isacord, etc. Also, cotton wrapped polyester thread releases thread lint that contributes to build-up of gunk in the machine. Some sewists have noted that they experience more sewing issues when using C&C threads. However, some machines will do better with certain thread brands than others, so some experimentation may be beneficial.
Third, check the stitch on your sample again. Generally, when thread loops appear on the underside of the fabric, it is the upper thread that is the problem. If loopy threads appear on the top of the fabric, it is the bobbin thread that is the issue. You can even use a different color in the top to help distinguish which thread is the problem.
Fourth, when threading the upper thread, Always Raise the Presser Foot during the threading process so the tension disk is released and the thread can seat properly. "Bird nesting" occurs when the thread is not seated in the tension disk.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Fifth, when the upper thread appears on the underside of the fabric, the upper thread tension is too loose. If the bobbin thread appears on the top of the fabric, the tension thread is too tight (or the bobbin thread is loose). Start out with the upper tension set at the midway point and tweak it from that point. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Also, remember that tension is not static--a tension setting for chiffon will most likely not work on cotton or denim. Get comfortable adjusting the tension to suit the project you are sewing.
May 24, 2016 | Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
When sewing a straight stitch the bobbin thread is loose and can be easily pulled out of the fabric. A Janome dealer replaced the bobbin housing but that did not correct the problem. Another Janome dealer...
When they serviced the machine, did they include stitch samples when the machine was returned to you? If so, then it would appear the machine was working properly at the time. Verify that you are threading the machine correctly--not skipping any thread guides along the way, inserting the bobbin turning the wrong direction. Verify everything you are doing with the manual.
My suggestion:
Take it back to the technician(s) who worked on it and request that he or she address the problem. Telling you to buy a new machine is not sufficient answer. They charged you a service call and did not repair it. If there are parts or more repairs required, they should be able to tell you what it would take and cost to accomplish having a working machine. From that point, you should be able to make your own judgment whether fixing it is economical or buying new is the better answer.
There are some things you can try but without knowing more of what the machine is doing, recommendations are difficult.
For one: remove the top thread from the machine and ALWAYS RAISE the presser foot when threading the top thread.
Install a brand new needle and verify that it is installed facing the correct direction.
Set the top tension to the midway point--this can always be tweaked.
If it is actually a tension issue, the following web sites may be helpful. Check how your top and bobbin tensions appear. If the bobbin thread still appears loose, the bobbin tension may need tightening. (The bobbin tension should have been properly set with the part was replaced.) You can try tightening the bobbin tension by turning the screw. CAUTION: mark the beginning point of the screw BEFORE making any adjustments so you can return it to the original point if things don't work. AND, turn only 1/8 to 1/4 of a turn at a time and recheck the stitch quality between turns.
Understanding Thread Tension Threads
May 20, 2017 | Janome Memory Craft 4000 Sewing Machine
Hello dear
have you tried changing the needle?
have you tried adjusting the top thread tension?
it might be the needle and the thread are not compatable,, the needle may be to light for the thread.
if the suggestions don't help, sew on the sewing machine till it makes the loop and then stop the machine and take it to the repair man and let him see the loop and then ask him why it's making the loop.
Jul 25, 2013 | Janome Sewing Machines
try changing the needle
rethread the machine top and bobbin
even try a different bobbin--make sure the bobbin is turned the right
make sure the top thread has not come off the thread take up lever
Dec 22, 2012 | Sewing Machines
I have a Janome Mycompact which is about 20 years old. When stitching, the thread from the bobbin is a straight line and the thread from the needle is perfect. How do I adjust or fix the way the bobbin...
Unthread the machine. Set the upper thread tension to 5 and raise the presser foot. Rethread the machine. With the presser foot up, pull about 12" of the upper thread through the needle and make note of how much tension you feel. Lower the presser foot and you should feel the thread get very tight. Also, make sure that you are using good sewing machine thread and not hand quilting thread, upholstery thread or too heavy weight thread for the machine.
Aug 03, 2011 | Janome Sewing Machines
I have a Janome that looks similar to the Sewist 625e and is 25 years old. The underneath threat of the stitch is knotting up underneath. I have checked that I have threaded top thread correctly. I...
Hi. It may be that you need to adjust the tension. Put a different color thread on top than is in the bobbin and sew a couple of inches, then check. I suspect you'll find that the top thread is the one that is loose and knotting up. (It's hard to tell unless you're using two different color threads.) If that's the case, your upper tension needs to be tighter. Tighten it just a bit, then sew a few more inches and check again. Repeat until you don't see any of the top thread on the bottom (or maybe just a little bit) or the bobbin thread on the top (or maybe just a little bit.).
Hope this helps!
Aug 11, 2010 | Janome Sewist 625e
Sewing Machines Logo
44 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
