Question about Refrigerators
Refrigerator door won't stay closed
My refrigerator door has stopped closing tightly. It's like the magnets aren't working or something. I have checked for any obstruction, cleaned the edges all around, checked the rubber barrier for dirt or obstructions and have found nothing. I have to really push each time I close the door to get a seal and if i open the freezer side, that pops open the refrigerator door. This isn't acceptable as it only takes one time to forget to push extra hard - then several hours later I can throw away the contents of the fridge! Stuff isn't staying very cold either. I turned the temperature to most cold. This is a Whirlpool ED25DQ side by side refrigerator.
  • jkennedy302 Jun 20, 2009
    Thanks for the suggestions! I tried all that but the thing I noticed was that the bottom grill had dislodged upwards and was causing part of the problem. It now closes without pushing hard but will still pop open when the freezer is opened and closed. I think maybe the gaskets are worn out although there is only one little corner that is worn. I will look into finding replacements. I can see the two doors aren't closing the same. The refrigerator door is sticking out a bit more than the freezer door.
    Guru:
  • 462 Answers
Pull on the gaskets some times they are broken and will take up moore room that when correctly aligned. especially on the side of the door where the hinges are. Inspect thehinges also see of brackets are loose. If the gasket is bunched up on the hinge side try duct taping them down and retry the door. If this corrects problem replace door gaskets. If a plastic grommet is missing in the door it will nolt align correctly and you will be able to pick up on the outer corner of the door and it will wobel and be loose on the hinge. ReplACE THE GROMETS and retest and align as nessary.
Posted on Jun 19, 2009
2012 open range refrigerator is closed but won’t stop beeping. It is acting like it’s open. Please help. Thanks.
I would look for some sort of door switch that is not engaging. There has to be something that tells the unit if the door is open or closed. This is the simplest and cheapest place to start.
Apr 28, 2018 | Refrigerators
Refrigerator Door does not stay closed until pushed solidly. The problem started a couple of weeks ago. Something wrong with the hinge?
the cams that close door either have cracked or warn oup replace the cams // they lift door and close them tight . a very common problem . and not too costly .. mm
Aug 11, 2010 | Amana ATB1832AR Top Freezer Refrigerator
My refrigerator Door (Whirlpool Gold)does not close like it shoul
You need to bend the door, if the gap is at the top put your foot between the frig door and the bottom and push the door closed slightly. so you can check it and do a small amount at a time. till tou reach the point that the door closes tight. if the gap is at the bottom put a shoe or something about 4 to 5 inches wide. go for it you can fix this..... saw
Dec 05, 2009 | Washing Machines
Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door itself...you see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Jun 05, 2009 | Refrigerators
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
Hotpoint side by side door problem
Check the refrigerator for level. Front can be a little higher than the back. Check for products that many be stored that may be holding the door from closing completely. Check the door hinges and make sure they are tight.
Apr 28, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
3,533 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
