Question about Garden
Mikita dcs6401 chainsaw wont start
Has spark but will not start
    Sergeant:
  • 458 Answers
How old is ths fuel in the tank? If it is older than 2 months dump it and put in fresh fuel. Use some starting fluid sprayed into the carb and see if it fires on that. It may take a few sprays to pull the old fuel through the lines till the fresh fuel gets to the carb.
Posted on Jun 12, 2014
dontbother10
  • 2220 Answers
SOURCE: wear is the model number on makita Gasoline
You can download both the Owner's Manual and Parts Breakdown for a DCS6401-PH here:
http://www.makita.ca/index2.php?event=tool&id=265&catid=40
The manual says the ID tag is in the rear handle below the trigger. HTH
Lou
Posted on Sep 21, 2009
dontbother10
  • 2220 Answers
SOURCE: Makita DCS6401 wont idle.
Have you tried resetting the "T" needle? Clean the air filter. Remove, clean and reinstall the muffler and spark arrestor. If no better posy back below please, with ALL you have done to try to fix it.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 23, 2010
  • 4088 Answers
SOURCE: chainsaw wont start. new plug has a little spark.
The engine case needs to be removed to expose the flywheel and ignition module. Check the module pole gap to the flywheel magnets with a thin business card for a gauge. If the gap is excessive, that can give a weak spark. If the gap appears to be correct, then it is probably time for a new ignition module. Make sure the spark plug is gapped at 0.020" before condemning the module. The spark should be blue and snappy. Check it in a dark area. Hope this helps!
Posted on Apr 17, 2010
  • 4088 Answers
Try turning the idle speed screw CW (not the jet screw marked L) one full turn to increase speed. Normally, this is set so that the chain stops moving, but the engine continues to run. Hope this helps!
Posted on May 15, 2010
puertobori
  • 7733 Answers
SOURCE: HOW DO I REMOVE THE
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Posted on Dec 17, 2010
Why will my saw not start, good spark new plug fresh gas
Sounds to me like a plugged up fuel line or old fuel in the fuel line. You may be able to clear it by spraying some starting fluid into the carb to pull the old fuel through. You only want to do this 2 times because this has no oil in it. Another suggestion it to remove the spark plug and put some of your fresh fuel mix directly into the chamber. About an eyedropper full should work.
Jul 13, 2015 | Makita DCS6401 20 20",64cc Chainsaw 2...
Makita dcs6401 chainsaw stopped in use want restart
remove the muffler and see if it starts if so open the muffler and clean the screen inside
Jun 10, 2012 | Makita DCS6401 20 20",64cc Chainsaw 2...
Saw will start but chain wont turn
Push the lever in front of the handle forward to release the brake
Jun 04, 2011 | Makita DCS6401 20 20",64cc Chainsaw 2...
What is the spark plug gap?
The spark plug gap for your saw is .020 inch or 0.5mm. Hope this helps.
Aug 29, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Makita DCS6401 wont idle. When the gas is released the chainsaw shuts off.
May 13, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Wont start
You need spark, fuel, and compression, which one is missing? Spark is easiest.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If spark is good put a small amount of fuel mix into carburetor throat. Does it attempt to start if yes, check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor are dirty or have failed.
Got spark, getting fuel but not flooded is beyond the our scope of help. I suggest a local chainsaw seller/mechanic for an estimate to repair. Your saw is made by Dolmar (Germany). I use a local Stihl dealer when my Husky problem is beyond something I want to repair. HTH
Lou
Oct 19, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
